Mitsubishi wd-y65 binking red light problemm
Hello... Your TV has a lamp that has probably gone bad. The lamp is accessible from the back of the TV, located towards the right side. There is a square-ish piece of plastic with one screw on the left side. Unplug the TV, open the cover and there are two silver screws on the left, top and bottom. Loosen the screws, and then grab the handle and pull out the lamp. It may be obviously bad, but if you're not sure, take it to a service center to get their opinion. Be careful buying a lamp online, some will not last long and some may not work at all. Mitsubishi TVs need the correct lamp to work properly. I hope this helps.
