Sony FD Trinitron WEGA KV-34HS420 34" TV Logo
A
Anonymous Posted on Apr 21, 2014
Green screen the screen stays green all the time.
Sony bravia shuts off
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Plasma tv green light flashes 5-6 times then stays green but no picture or sound
Remove one at a time the Y sus and Y buffer cables that go to the power board and see if the set stays on then, you may have a distorted pic, replace the board that makes the set stay on...there are some transistors on the buffer board that give issues a lot and I'd guess that's where your issue is at
LG LCD 37" GREEN STANDBY/POWER LIGHT FLASHES GREEN NINE TIMES
http://www.tvrepairkits.com/?gclid=CP-_rIXGgbICFUXHtAodv3QAUA Take a look Kolbrun
2answers
D52W20BYX1 Green problem
I would go back to green tube disconnect ,unplug CRT board to green tube if set stays up playing its the tube.
Dell e770 Monitor
It sounds like the picture tube in the monitor has burned out. Time to replace.
Vertical green lines
It sounds like th green LCD panel laminations or bonding has separated and this is causing your green lines. The optical block would have to be replaced to solve the problem.
5helpful
2answers
DS lite, power is on but nothing happens
Ditto... except my daughter is 10. Both screens remain black, are fully charged and green light stays on for more than 4 minutes.
Green screen
Something is wrong with the TV :-)
Seriously, though, call a technician. Call me on 0414 635 468 if in Melbourne.
Something is causing green tube to stay on all the time. Could be the tube itself or driving circuitry. Certainly not a user repairable fault.
RUdolf
Ps3's green light turns on usually screen stay's black
Call Sony so they can fix it. This sounds like multiple problems. Good luck.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
