The truss rod adjustment is on the body end of the neck, not at the headstock.
You need to;
remove the strings
unscrew the neck from the body
Make a small adjustment
Re-attach the neck
Re-string the bass
rinse and repeat until satisfied
http://support.fender.com/service_diagrams/p_bass/014-6500-323A_SISD.pdf
SOURCE: how to adjust the neck on a fender jazz bass
depending on the model you will see a place for an allen wrench. it will be either on the end of the neck half way under the body, or most likely at the headstock just under the fret board. Find the correct size allen wrench and turn it about a 1/4 turn at a time. im not sure why your looking to adjust your neck so i cant really say what to look for.
