I would like to turn off the voicemail or increase the number of times the phone rings before the Voicemail picks-up. Can you help?
SOURCE: trying to change number of rings before voicemail
By default individual coverage is set to 45 seconds. Ask your phone vendor to reduce it.
SOURCE: Avaya Euro 18D Voicemail Light
If the voicemail you want to use is Verizons, it will NOT light the light on your phone.
For that to happen, you would need a voicemail through the phone system
SOURCE: My voicemail indicator message lamp stays on.
What voicemail do you have?
Vm Pro or embedded?
If voicemail pro, you will need to navigate to the folder where your messages are stored on the pc, delete them, then stop/restart the vmpro services. If you dont know what I am talking about, I would call someone in that is a knowledgeable tech....
SOURCE: Change the number of rings before voicemail comes on
Sorry, but it appears that your phone does not offer that option. Need the full manual? You can download/print it here:
http://support.avaya.com/css/P8/documents/100010555
SOURCE: change main number voicemail
There is no default way to do this. The technician that set the system up will need to tell you the code to get in aand modify that wav file. There is no way to do so by default, it has to be set up, and can be anytihng.
Look at your config, for a short code that goes to a "vociemail collect" with the name recordings.....that is the code you use to modify.
