When the car is started there is a tic, tic, sound like the signal light and a button on the remote starter has to be pressed for it to stop. After running the car and stopping, it won't start. The remote starter does things on its own - starts the car, emergency horn goes off. There is a problem with it. Can I disconnect it totally?
SOURCE: viper remote starter-
The start/stop 3x thing could be one of a few main issues. You need a bypass module or it needs to be reset. You need to program the tach if you're using it. Make sure with the new models(5101, 5301) it's programmed for auto transmission. The come default for manual transmissions.
SOURCE: Viper 5900 remote start does not show it is off on the remote.
try a couple of things, 1) try unplugging the anntena for the alarm for about 5 minutes. 2) remove battery from remote for 5 minutes 3) reprogram the remote
SOURCE: my remote car starter starts my car without
You probibly have it set for cold weather start or something
SOURCE: when using the remote starter the car won't start
have your ignition relay for the remote start checked out.could b a blown fuse.
SOURCE: my avital 4113 car remote
DEI sent out a recall on a batch of theit antennas for this sysetm that were remote starting the car by its self. If you call customer service they will send you a replacement antenna and this sould fix your problem.
i have a ungo sr 6000 i missed placed my lcd 2-way remote so i only have the secondary 4- button remote. How can i disable the timer auto start!!!!!!!!! PLEASE HELP ASAP !!!!!!!!! GOIN BROKE ON WASTED GASSS!!!!!!!!!!!!!!
