Canon ZR85 Mini DV Digital Camcorder Logo
A
Anonymous Posted on Apr 21, 2014
Canon zr85, battery won't charge
My camera won't stay on unless it is plugged into the wall. The battery will not charge.
Jim Jordan
Level 3:
Master:
  • Canon Master 442 Answers
  • Posted on Jun 02, 2014
Jim Jordan
Canon Master
Level 3:
Master:
Answers
442
Questions
0
Helped
114763
Points
1360
It sounds as if your battery is shot. If it does it with any battery then that's not the case, of course, but a Batteries Plus store can test it for you or you can just order a replacement from Amazon. I've had good luck with Wasabi Power replacement batteries from Amazon.com.
5 Related Answers
Anonymous
  • Posted on Jan 12, 2009
SOURCE: My Canon ZR85 has no
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Anonymous
  • Posted on Nov 13, 2008
SOURCE: Cassate tape will not eject from my Canon ZR85 Mini DV Digital Camcorder
I found a temporary solution for this problem. When the tray with the cassette tape comes out remove the battery so that the tray will not go inside again. Now on top of the tray it will be written as "PRESS" just adjucent to it you can see a spring connected to the tray just press the string down wards and the tray opens and you can replace the battery. Hope this can help.
Anonymous
  • Posted on Sep 02, 2008
SOURCE: Canon ZR85 camcorder won't turn on
Steps for removing the tape from a totally dead ZR85:
1. Turn camera upside down.
2. Move "Open/Eject" button to full right position (toward lens).
3. Manually push tape door open.
4. On the metal surface that sits between you and the tape, there is a very small screw. There is probably a yellow sticker next to the screw that says "Do not press on this part". With a small jewelry phillips screwdriver, remove that screw.
5. Push the metal plate (with tape) in the direction ofr the door and lift slightly. The metal assembly holding the tape comes loose, exposing the top of the tape.
6. Pull the tape upwards (out of the camera). At this point, the tape will still be engaged in the play heads. With the cartridge out far enough to see the heads, reach in with your jewelry screw driver and carefully lift the tape over the heads, and free from the camera.
7. Use the eraser on the end of a pencil to wind your tape back into the cartridge.
8. When re-assembling the mechanism in the camera, there are two curved slots on both sides of the piece you took loose. You'll need to thread these onto two posts inside before you place the top back in position and put the screw back in.
Anonymous
  • Posted on Feb 17, 2010
SOURCE: NTSC ZR65 MC
can this camcorder (canon ntsc zr65 mc ) can the video be downloaded to my mac laptop?
tscmusa
Mitch Davis
  • 95 Answers
  • Posted on Mar 26, 2010
SOURCE: Computer reconized canon zr85, but not the zr800
load or reload the drivers for the zr 800,you should be able to get the drivers off of canons website
1helpful
Why is my Canon FS10 Flash Memory Camcorder flashing red when trying to charge?
i kindly recommend you reset teh camera ,also check battery contacts inside the camera and on the battery itself are clean and free from dirt or corrosion.In addition,you can alos buy a new battery
2answers
Kodak easyshare won't work unless plugged into charger
Hello Pam, You have either a faulty contact for the battery or your battery is suffering from age. After time these camera batteries lose their capacity. Try a new fully charged battery.
Best Regards, Russell
2answers
I have a Canon ZR85A where the LCD screen as well as the eye viewer is a cloudy screen, not being able to see actual image to record. I thought I fixed the problem as I replaced the backup battery. The...
Any battery will lose the ability to take a charge if left unused for over a year. Replace all the batteries, charge them fully, and re-charge them at least once a month.
I have a canon digital video camcorder NTSC ZR85. I am unable to charge the battery. I have changed the battery but still there is no charge for the battery. I am unable to see the charging light. What are...
This is usually caused by a failed component in the power circuit within the camera and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I
1helpful
1helpful
3answers
4answers
Not able to record the image
I had a similar thing happen to me...the video would not come one when I turned it on, but the audio would work, and it would play back tape fine. I happened upon the following solution (though I don't know how long it will last). I charged the camera, and then noticed it worked fine when the charger was plugged in. As soon as I unplugged it, the video would go black. So...I plugged it in, turned it to record, and unplugged it, and it worked! Almost like something got reset. I have no idea how long this will last, or if it means the battery is going...but, give it a try!
Top Canon Video Cameras Experts
NOEL
NOEL
john h
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
