No you don't need any special tool . Find all screws on out side of door trim panel and the window handle , the mirror cover plate , then just pull on edge of the panel .
Gently pry the front side door trim panel (3) from the front side door by disengaging the plastic retainers which secure the panel.
Position the door trim panel (3) away from the door in order to gain access to the front side window switch electrical connector, if equipped.
Disconnect the window switch electrical connector, if equipped.
Remove the door trim panel (3) from the vehicle.
Remove the front side window switch from the door trim panel (3) by releasing the 4 plastic retaining tabs, as needed.
Use a cloth in order to pull off the snap ring which secures the front side door window regulator handle (1), if equipped.
Remove the window regulator handle (1), if equipped.
Remove the front side master window switch, if equipped. Refer to Power Accessory Switch Panel Replacement .
Remove the front side door inside handle (1). Refer to Front Side Door Inside Handle Replacement .
Remove the outside rearview mirror opening cover (2).
Remove the screw which secures the front side door pull handle (4).
Removal Procedure
Remove the screw which secures the front side door inside handle (1).
Slide the inside handle (1) forward in order to release the retaining tabs which secure the handle to the door.
Open the front side door inside handle rod retainer and remove the front side door inside handle rod from the inside handle (1).
Remove the inside handle (1) from the vehicle.
Important: When removing a door trim panel or switch plate, disconnect the negative battery terminal. This will eliminate the possibility of shorting out the switch if you use a screwdriver, an awl, or other metal object in order to remove the switch from the harness.
Remove the window regulator handle, if equipped. (manual windows only) Remove the front door warning reflector. Remove the door panel screw (1) through the hole in the door warning reflector opening. Use a flat bladed tool in order to remove the rear deck release switch bezel. Disconnect the rear deck release switch. Use a flat-bladed tool in order to remove the lower switch bezel trim screw access cover. Remove the lower switch bezel trim screws. Remove the lower switch bezel trim panel. Use a flat-bladed tool in order to pry the front door switch bezel upward. Disconnect: Power door lock switch connector, if equipped. Power window switch connector, if equipped. Power mirror switch connector, if equipped (left side only). Gently disengage the front door trim retaining clips and remove the door trim panel from the door.
Position aside the front door watershield to gain access to the exterior
rear view mirror control switch electrical connector.
4.Disconnect the exterior rear view mirror control switch electrical connector
as you see you have to remove the door panel to have access to the electrical connector in case that you dont know how to do it here are the instructions
NOTE: Left front door trim panel shown, right front door trim panel
similar.
Remove the sail panel.
If equipped, disconnect the electrical connector
If equipped, lift up and remove the exterior rear view mirror control switch
panel.
Disconnect the electrical connector.
If equipped, lift up and remove the window control switch panel.
If equipped, remove the window regulator handle.
Position the window regulator handle cover aside.
Remove the window regulator handle screw and regulator
handle
5.Remove the door trim panel center screw cover 6.Remove the 2 door trim panel center screws 7.Remove the 2 door trim panel lower screws
NOTICE: Do not pull directly outward on front door trim panel as
damage will occur. Remove the front door trim panel.
Lift upward to remove the front door trim panel.
NOTICE: Insert the lower panel tabs first or they can break when
installing the front door trim panel. To install, reverse the removal
procedure
Disconnect the negative battery cable. Important:When removing a
harness.
reflector opening.
bezel.
access cover.
Disconnect:
Installation Procedure
Install the front door trim panel to the door. Ensure that the retainers are locked into place.
Connect the rear deck release connector.
Install the rear deck release switch bezel. Press the bezel firmly into
place.
This is for the front passenger side door panel from a 1999 Ford Expedition. The
driver's side door should be the same, except for the mirror switch
which needs to be unplugged. The 1998 *might* be the same, I don't know,
but this should be helpful to someone.
Use a flat blade screwdriver or other suitable tool to pry out on the
top of the triangular plastic panel on the top front of the door panel.
The plastic holder should pull out of the door. Now pry up on both sides
of the triangular panel and pull it loose. Remove the philips head
screw you find under this panel. Pull the door latch handle, pry out the
insert where the handle goes through, and remove the bolt that holds
the door handle in place. Remove the door handle. Pry up on the ends of
the door switch panel to remove it. Unplug the cables by pushing in on
the lock tab on the side of the plug and pulling out. Remove the philips
head screw accessible through the switch panel hole. Insert a flat
blade screwdriver into the slot at the bottom of the courtesy light lens
and pry up and out to remove the lens. Remove the philips head screw
behind this lens. Pull up on the door panel to remove it. Be careful of
the courtesy light when removing the panel - give the light a quarter
turn counter-clockwise from the rear to remove it from the door panel.
Its possible that this GUIDE can helpfull as reference.
most likely needs a latch... remove the screws from the panel, probalbly one behind the handle, some in the armrest and some along the bottom. possibly one under the window switches, window switches pull up away from panel. when all screws and window switchesremoved pull up on panel to remove.
please rate if this helps.
Section 01-05: Trim, Interior
1995 Thunderbird, Cougar Workshop Manual
REMOVAL AND INSTALLATION
The interior trim component Removal and Installation procedures generally apply to all models. If some of the steps do not apply to the particular models being serviced, proceed to the next step.
Trim Panels, Door
CAUTION: Do not pry front door trim panel (23942). Prying on front door trim panel will break the hook retainers.
Disconnect battery ground cable (14301) .
Carefully pull front door trim panel finish panel (23712) away from front door trim panel .
Item
Part Number
Description
Front Door Trim Panel Finish Panel
17B676
Outside Rear View Mirror Control
Door Lock Switch
55928-S55
Screw (5 Req'd)
5
14529
Window Regulator Control Switch
6
23942
Disconnect wires from front door lock switches (14017), outside rear view mirror controls (17B676) and window regulator control switches (14529) , if equipped; remove front door trim panel finish panel.
Remove front door trim panel retaining screw through front door trim panel finish panel opening.
Trim Panels, Door
Item
Part Number
Description
Front Door
383356-S100
Nut (2 Req'd Each Side)
56903-S58
Screw (2 Req'd Each Side)
Remove interior lamp lens cover.
Remove screw through interior lamp opening.
Slide front door trim panel upward to disengage hooks.
Rotate top of front door trim panel away from front door (20125) , and lift bottom hooks from front door.
does it act the same whether you use the driver door switch or the passenger door switch? Please rate as fixya if this helps. thanks
here's repair procedure
Window Regulator, Front Door, Explorer
Removal WARNING: IF THE REGULATOR COUNTERBALANCE SPRING MUST BE REMOVED OR REPLACED FOR ANY REASON, MAKE SURE THAT THE REGULATOR ARMS ARE IN A FIXED POSITION PRIOR TO REMOVAL TO PREVENT POSSIBLE INJURY DURING C-SPRING UNWIND.
Remove front door trim panel and front door trim shield . Refer to Section 01-05B .
Trim Panel, Front Door, Explorer Hi-Series, Two-Door and Four-Door
Remove the two screws retaining the front door trim panel (23942) located above the window regulator handle (23342) . Also remove one screw in the upper front portion of front door trim panel .
Remove inside door handle cup (22634) at the window regulator handle using a screwdriver or sharp object. Retention nibs will flex for easy removal.
To remove window regulator control switch (14529) and outside rear view mirror control (17B676) , use notch located at lower end of outside rear view mirror control using a screwdriver to lift and remove.
Remove outside rear view mirror control from front door trim panel pulling wire harness from inside of front door trim panel .
From bottom of outside rear view mirror control, remove two screws and disconnect connector from switches.
NOTE: Do not pull on the front door trim panel to remove clips from the inner panel holes.
At each plastic clip location, pry the front door trim panel away from the door inner panel using the front door trim panel removing tool from Rotunda Moulding Trim Kit 107-00401 or equivalent.
NOTE: Pay special attention to the cut-out in the door trim panel for the door handle, so that it clears the handle during removal without breakage.
When wiring and disengagement of trim clips is completed, it is recommended that to remove panel, lift slightly to remove flange at the top of door trim panel from trough in the glass weatherstrip.
Disconnect socket and bulb from illuminated interior lamp (13776) before total removal of front door trim panel.
For installation, follow removal procedures in reverse order. Replace any bent, damaged or missing plastic clips on the front door trim panel to the front door trim panel , firmly loading clips into slots provided on front door trim panel .
Trim Panel, Front Door, Explorer Hi-Series Four-Door
Remove inside door belt weatherstrip and glass stabilizer.
Remove front door window glass as described in this section.
Remove two nut and washer assemblies attaching the equalizer bracket.
Remove three rivets (manual) or four rivets (power) attaching the regulator base plate to front door trim panel finish panel (23712) .
Remove window regulator electric drive and front door window channel bracket from vehicle.
Working on a bench, carefully bend tab flat to remove arm slides from front door window channel bracket .
Install new window regulator electric drive arm plastic guides into front door window channel bracket and bend tab back to 90 degrees.
Use care not to break tab; if tab is cracked or broken, replace front door window channel bracket . Make sure rubber bumper is installed properly on new front door window channel bracket , if replacement is made.
Installation NOTE: The front door window channel bracket and window regulator electric drive are installed into the vehicle as one assembly. The front door window channel bracket may be disassembled from the window regulator electric drive as described in Steps 7 and 8 of Window Regulator, Removal.
Install front door trim panel finish panel with preassembled glass bracket into vehicle. Set the regulator base plate to window regulator electric drive using base plate locator tab as a guide.
Install three (manual) or four (power) rivets (385189-S100) to attach regulator to front door trim panel finish panel .
Two 1/4-20 x 1-inch bolts and two 1/4-20 nut and washer assemblies may be used as alternates for glass retention. However, torque must not exceed 4-7 Nm (3-5 ft-lb). Equivalent metric retainers may be used.
Install equalizer bracket.
Install inside door belt weatherstrip and glass stabilizer.
Lower regulator arms to access holes in front door trim panel finish panel . Install front door window glass as outlined.
Adjust glass to ensure proper alignment with glass run. Cycle glass for smooth operation.
Install front door trim panel and front door trim shield . Refer to Section 01-05B .
Carefully pull front door trim panel finish panel away from front door trim panel.
Disconnect wires from front door lock switches, outside rear view mirror controls and window regulator control switches, if equipped. Remove front door trim panel finish panel.
Rotate top of front door trim panel away from front door and lift bottom hooks from front door.
Disconnect window regulator jumper wire
Remove front door trim panel.
