Had a new leisure battery fitted last week. It all worked fine until today. All the auxillaries and control panel work when we are hooked up or the engine is running, but not through the leisure battery. Please help.
have your alternator (charging system) checked it sounds like battery is not receiving a full charge either due to faulty alternator, or battery cable corrosion.hope this helps
I know it seems obvious, but sometimes over the summer people shut off their pilot light, and when relighting forget to move the pilot knob back to the "on" position after the pilot is going - check this first. Next, you can slide the switch on the Skytech 5301 receiver from "remote" to "on" and verify that it lights the burner. If it does, you may need to re-sync the remote to the receiver. If it does not, check to make sure your wires are nice and tight on the TH & TP/TH connections of the valve. If you are still having trouble, Skytech has a toll-free hotline for tech support on the 5301. It is: 1-888-672-8929 8am-5pm EST.
Check the master window control panel on the drivers door. There is probably a lockout switch. It may have a window outline on one end and the same outline with an "X" over it on the other. Press the outline without the "X" and all your windows should work again. As silly as that sounds, a lot of folks hit the lockout switch and don't know it. On the other hand, the lockout switch is bad.
Sounds like you have a heatpump. Is that correct? When it gets under 35F or so the heatpump just isn't able to keep up with the heat demand and will require help from a backup source such as electric strip heaters. The way the thermostat works is that the heatpump will work until room temperature gets 2F to 4F below what you have the thermostat set for, the Auxillary heat will kick in to help out. I think I am answering your question, please let me know if I have misread your problem and I'll try to come up with something else.
I have had the same problem today. I think it might be to do with the master power button on the side, as it seems loose on my tv. Did you ever solve the problem on yours?
Check for vaccum hoses attached to the cruise control module in engine compartment. These hose may be try rotted and your loosing vaccum when you activacte cruise control.
You may just have a bad remote or the IR sensor in the TV may be bad. Bring the remote to a store that sells Protron and try it. You may be able to get a new one if it is bad http://www.protronusa.com/contact.php
