On the printer press the menu button until you reach MAINT.Then press the item + button until you reach DRUM CT RESET. Then press select.YOUR DONE!!!!!!!!
The toner cartridge is only a supply chamber. The cartridge simply dumps toner into the feed hopper in the drum. When you change the drum the feed hopper is empty and it is likely that the cartridge dropped the last of it supply into the hopper - ergo it is now empty. I recommend shaking the toner back into the cartridge before separating the cartridge from the drum unit when changing them
The problem is most likely with your fuser and will need to be replaced. Contact Oki tech support and see if your printer is still under warranty, you will need to give them your printer's model number and serial number. Sometimes the cheapest solution is to replace the printer all together.
You will need to replace the printer's drum cartridge. Just google oki b4600 drum to get hold of one. In the package will be a reset routine to follow when you do this.
