Proscan 10.1-Inch Internet Tablet, Capacitive Touch Screen, Android 4.0 with Front Camera, 1.2 GHz, 1 GB RAM" Logo
A
Anonymous Posted on Apr 20, 2014
HDMI Switch has stopped
At start-up, there is a message that the HDMI switch has stopped, there is a problem box with the option to click the, ok tab, but tab will not clear
I have a Galaxy Tab s 8.4 and the wi fi has stopped working and won't switch on. other items connected to the wi fi are working ok.
Hi
Look around the sides or front and back there is a button on your galaxy tab somewhere around the edge;s there is a button to be turned on try it
thanx tom
How do I change from Spanish to english
  1. Open Regional and Language Options by clicking the Start button , clicking Control Panel, clicking Clock, Language, and Region, and then clicking Regional and Language Options.
  2. Click the Keyboards and Languages tab.
  3. Under Display language, choose a language from the list, and then click OK.
I have the AK352 it frooze up did the reset process.. Now it has no memory its either blank blue screen or the Irulu connecting my world white screen I need to download the memory back on it..
you can try this
• First switch off your device.
• And then wait for some time and then get it restarted by pressing the `Power+Volume Up+Down` buttons all at once.
• Now you will be taken to the option of `Recovery Mode` tab.
• In that mode select the option of `Wipe/Factory reset data` tab using the volume keys to scroll and use power to select
• Once you select power it will reboot your tablet
• It will switch off and switch on back again this time it won't freeze on your start up screen
or you can email them
http://www.irulu.com/Home/ContactUs
2answers
How do I set up a hotmail
How to Create Hotmail Account
hi there
If you open this link, there is a step by step instructions how to create an Hotmail account.
best wishes
kolbrun
My audiovox 7 inch tablet reads hdmi is turned off, and ui is not working,, also it wont function when I press ok
For some tablets, the HDMI port must be connected to a TV before you can enable HDMI.
Where do I go in the system to set the default storage to the sd card?
SD storage card restore to defaults
Click start click to open on my computer you should see your usb drive F: or something right click select properties there will be an array of options select the sharing tab option then advanced sharing
permissions make sure you have a tick in the share this folder box then click permissions make sure all three boxes are ticked you full control change and read in windows 7
Click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
also
If you are running a Windows XP OS then you might be able to:
Click start right click on my computer select open
Right click the icon of your Flash Drive (It should be F: / E: or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
you might have restore it to its defaults
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
Take Off Write Protection on an SD Card
Secure Digital (SD) flash memory cards are a common storage format for mobile devices.
By default, they allow both reading from and writing to the card.
However, they can be set so you can only read from the cards and not write to them.
Some cards are created as read-only by default.
Other times, a faulty card reader may mistakenly read all cards as read-only.
In both cases, you can make simple changes to the card to disable the write protection.
1.
Orient the card so the label is facing up.
Slide the write protection tab, which is located on the left side of the card, to the unlocked position.
If there is no write protection tab, skip to Step 4.
2.
Test the card in your computer.
Insert the card in the SD slot and open the folder to view the files.
Try to save a file onto the card or right-click an existing file and select "Properties," then uncheck the box marked "Read-only."
3.
Remove the card and check to see the write tab is still set to "unlocked" if you get a message that says it is still write-protected.
If it has become locked again, slide it back and tape it in the unlocked position.
4.
Place a piece of masking tape over the notch in the SD card located on the right side of the card. Make sure the tape does not cover any of the card's metal contacts.
Test again as in Step 2.
5.
Cover the notch with a second layer of tape if the card is still giving you problems.
http://www.getflashmemory.info/hack-why-is-my-sd-card-write-protected/
2helpful
How do I delete browser search history from Acer a200?
to create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help
click on the tools at the bottom of the drop down list will be internet options you will a box with delete browsing history on exit tick in the box or select setting where you be able to change the options
every time i visit a webpage
every time i start internet explorer
automatically
and never
you can also view the files or objects
hope this helps
How do i delete browser search history from acer a200
automatically
and never
hope this helps
24helpful
2answers
Galaxy p1000 is frozen cant switch off nothing is happening
Hope this helps:
How to Hard Reset Samsung GT-P1000 Galaxy TAB:
If your Samsung GT-P1000 Galaxy TAB is frozen and unresponsive, press and hold [POWER ] for 8-10 seconds. The device will reboot automatically.
If this does not solve the problem, perform a factory data reset. In Menu
mode, select Settings ? Privacy ? Factory data reset ? Reset phone ? Erase everything.
Hard Reset Samsung GT-P1000 Galaxy TAB with keys With the Samsung Galaxy TAB turned off, press and hold the VOLUME DOWN button, and then briefly press the POWER button.
Device manager not work properly & Modem not found
Check if the service is running, enter msconfig in the Start => Run box. Open the Services tab in the System Configuration utility's window. If the Plug and Play service isn't listed, uncheck the option in the box beside Hide All Microsoft Services. The option for the Plug and Play service should be enabled and should be shown to be running. If it isn't running, right-click the My Computer entry on the Windows Start menu and choose Manage. On the Computer Management window, expand the entry for Services And Applications and click Services. Make the Standard tab display its contents and locate the entry for Plug and Play. Double-click this entry and set the Startup type to Manual. Next, click the Start button under the Service type in the same window. The service should start, and the window can be closed. Should any warnings appear during this process, just click OK. The Device Manager should now be displaying all of its information
Please rate this fixya
Top Proscan Tablets & eReaders Experts
 Mikey
Mikey
Ngoro
ADMIN Andrew
ADMIN Andrew
Are you a Proscan Tablet and eReader Expert? Answer questions, earn points and help others
