Good Morning Paul, thank you for your post!
Based off what you have described your Frigidaire range, PLES389DCC, is providing you with an error code of "PF" and "F1" as soon as you turn it on. An error code of "PF" stands for power failure this could be a possible problem with your control panel or power cord.
The error code "F1" stands for a runaway temperature (overheating). This could be an issue with your RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control). I would recommend performing a reset on your oven and you can do that by disconnecting from your oven for ten minutes. If you continue to have issues with the "F1" error code I would recommend having a professional technician out to your home for proper diagnosis and replacement of any electrical components. Hopefully this information has been helpful. -Matt
Hello friend, thanks for your post!
I understand that the spin feature on your Frigidaire washer is spinning slowly. It sounds like a potential problem with your motor control board or control board. I would recommend performing a reset and you can do that by disconnecting the power from your washer for roughly ten minutes. If that does not help correct the issue I would recommend having a professional come out. They will be able to pinpoint the cause of the issue and replace any electrical components to avoid any personal injury or future issues with your washer. -Matt
Good Afternoon friend, thank you for your inquiry!
Based off the information you have provided you replaced the control board and continue to experience troubles with your Frigidaire refrigerator. Normally an "EF" error code stands for evaporator fan circuit failure. This could be an issue with your evaporator fan or main control board. I would suggest consulting with a professional for proper diagnosis to avoid any unnecessary part purchases. I hope this helps to some degree. -Matt
