What happens if somene tried to clean a self cleaning GE Profile oven? It wasn't with anything like windex... and it was only one time. Does that mean the self cleaning feature will no longer work? Or is it that over time it would hurt it, but once is ok?
There is nothing wrong with cleaning a self-cleaning oven. Now, I don't have experience with your speicific oven, but I do have experience with other self-cleaning ovens. The self-clean function simply heats the oven up really hot. The actual temperature varies but the oven will get hotter than the hottest temperature setting. What happens is that when it get that hot it actually burns up spilled food and crumbs. sometimes in mine I even see small flames. The oven usually requires you to lock it as well since the temperature will be so high. Eventually you have to clean out the burnt "ashes" which are basically the stuff you get on food if you burn it. So the answer to what happens if you clean the oven is that you get a clean oven, nothing else. It won't hurt the oven at all. As a matter of fact even if you use the self-cleaning feature you will eventually have to clean out the "burnt crumbs" and such by hand anyway. So self-cleaning oven are designed to be cleaned by hand as well. And you won't hurt it by doing so even if you did it every day.
don't understand the question
