Schwinn 430 Elliptical Trainer Logo
A
Anonymous Posted on Apr 19, 2014
How to change from miles to km - Schwinn 430 Elliptical Trainer
1helpful
2answers
Change from km to miles on a chrysler 300 2013
On your steering wheel, you will see on your left some arrows (up, down, right direction), push the right arrow and change the settings from KM to Miles
I have a giant prime + e bike ,2014. How do I change from km to miles?
To change the unit of measurement on your Giant Prime+ e-bike computer from kilometers to miles, you can follow these steps:
  1. Turn on the computer by pressing the button on the underside of the unit.
  2. Press and hold the "Set" button until the screen changes.
  3. Press the "Set" button repeatedly until you see "UNIT" on the screen.
  4. Press the "Mode" button to select "UNIT."
  5. Press the "Set" button to confirm your selection.
  6. Use the "+" and "-" buttons to toggle between "KM" and "MILE."
  7. Press the "Set" button to confirm your selection.
Once you have completed these steps, your Giant Prime+ e-bike computer should display speed and distance in miles instead of kilometers.
2answers
How to reset change oil soon light
Oil Life Monitor Resetting (KD, KE)
Description
The engine oil life monitor will indicate when to change the engine oil and the engine oil filter - usually between 5 000 km (3,000 miles) and 12 500 km (7,500 miles) since the last oil change. Under severe conditions, the CHANGE OIL message may be displayed before 5 000 km (3,000 miles). The vehicle must not be driven more than 12 500 km (7,500 miles) or 12 months without an oil change.
The engine oil life monitor will not detect dust in the oil. If the vehicle is driven in a dusty area, be sure to change the oil every 5 000 km (3,000 miles) or sooner if the CHANGE ENGINE OIL message is displayed.
Reset the oil life monitor when the oil has been changed.
Resetting Procedure
Press the INFORMATION SKIP button on the DIC control panel in order to display the OIL LIFE LEFT message.
Press and hold the RESET NO button until the display shows 100% ENGINE OIL LIFE.
How do I change the mileage from kilometers to miles on my 2009 Ford Fusion?
I km = .62 miles.
10000 km = 6200 miles.
Check car manual to see if the display can indicate miles in lieu of KM's
At what mileage should the timing belt be changed on a citroen berlingo
What does your owners manual say?
60,000 miles/36 km
75,000 miles/45 km
90,000 miles/54 km
Not more than 90,000 miles or
6 years
If it breaks,the valves get bent
Call a dealer or stop by & ask
Alfa romeo 147 flashing dasboard
This is so you can set it, just set or reset the time on the clock and it will stop flashing, same thing with the km,move from km to miles and back, if you want km then set to km but if you want miles then go to miles but you must select through it, good day.
2helpful
3answers
Reset oil change milage
GM OIL LIFE SYSTEM - RESETTING
The engine oil life monitor will indicate when to change the engine oil - usually between 5 000 km (3,000 miles) and 16 000 km (10,000 miles) since the last oil change. Under severe conditions, the "CHANGE OIL SOON" light may be displayed before 5 000 km (3,000 miles). The vehicle must not be driven more than 16 000 km (10,000 miles) or 12 months without an oil change.
Reset the oil life monitor when the oil has been changed, use the following procedure:
  1. Turn the ignition key to the RUN position.
  2. Fully push and release the accelerator pedal 3 times within 5 seconds.
  3. If the Change Oil Soon light flashes, the system is resetting.
  4. Start the vehicle.
  5. The oil life will change to 100%.
  6. If the Change Oil Soon light comes back on, the system has not reset. Repeat the procedure.
Trying to find the owners manual for 2001 saturn sc2 as well as the maintenance schedule etc provided when the car was new
Scheduled Maintenance The service shown in this schedule up to 150,000 miles (250,000 km) should be performed after 150,000 miles (250,000 km) at the same intervals.
See Owner Inspections and Services for maintenance information.
Scheduled Maintenance Mileage
Maintenance Group No.
6,000 Miles (10 000 km)
18,000 Miles (30 000 km)
30,000 Miles (50 000 km)
36,000 Miles (60 000 km)
42,000 Miles (70 000 km)
50,000 Miles (83 000 km)
5
54,000 Miles (90 000 km)
60,000 Miles (100 000 km)
6
66,000 Miles (110 000 km)
72,000 Miles (120 000 km)
78,000 Miles (130 000 km)
90,000 Miles (150 000 km)
7
100,000 Miles (166 000 km)
8
102,000 Miles (170 000 km)
108,000 Miles (174 000 km)
114,000 Miles (190 000 km)
120,000 Miles (200 000 km)
6
126,000 Miles (210 000 km)
138,000 Miles (230 000 km)
150,000 Miles (250 000 km)
5
Maintenance Requirements - Group 1 • Rotate the tires. See Tire Inspection and Rotation for the proper rotation pattern and additional information. • Inspect the brake system. Check the brake calipers for freedom of movement and lubricate if required. • Inspect the exhaust system and shields. • Lubricate the door hinges, check links, hood and sunroof (if equipped). Maintenance Requirements - Group 2 • Rotate the tires. See Tire Inspection and Rotation for the proper rotation pattern and additional information. • Inspect the brake system. Check the brake calipers for freedom of movement and lubricate if required. • Inspect the exhaust system and shields. • Lubricate the door hinges, check links, hood and sunroof (if equipped). • Inspect the engine accessory drive belt and coolant hoses every 12 months or 18,000 miles (30,000 km), whichever occurs first. Maintenance Requirements - Group 3 • Rotate the tires. See Tire Inspection and Rotation for the proper rotation pattern and additional information. • Inspect the brake system. Check the brake calipers for freedom of movement and lubricate if required. • Inspect the exhaust system and shields. • Lubricate the door hinges, check links, hood and sunroof (if equipped). • Replace the engine air cleaner filter every 36 months or 30,000 mile (50,000 km), whichever occurs first. An Emission Control Service . (See footnote) • Inspect the vacuum lines/hoses every 24 months or 30,000 mile (50,000 km), whichever occurs first. An Emission Control Service . (See footnote) • Replace spark plugs. An Emission Control Service.
37helpful
Reset distance mode in miles/not km
http://www.sportline.com/manuals/345.pdf
to change from km to miles or from miles to km... press and hold the reset button for (at least) 5 seconds (while in the distance mode.) This will reset your already walked info.
2002 Jeep Grand Cherokee Limited pre form service needs to be erased
Service Interval
When this feature is selected a service interval between 2,000 miles (3,200 km) and 6,000 miles (10 000 km) in 500 mile (800 km) increments may be selected. Pressing the STEP button when in this display will select distances between 2,000 miles (3,200 km) and 6,000 miles (10,000 km) in 500 mile (800 km) increments.
Reset Service Distance (Displays Only if Service Interval was Changed)
When this feature is selected the current accumulated service distance can be reset to the newly selected service interval. Pressing the STEP button when in this display will select "Yes" or "No."
Top Schwinn Exercise & Fitness Experts
john h
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you a Schwinn Exercise and Fitnes Expert? Answer questions, earn points and help others
