Question about Epson Workforce Pro Wp-4540 All-in-one Printer W/inks brand New
I have an air bubble in the blue ink tube and it is not coming out even after several cleaning cycles. I am not able to access the cartridge like the older models so I cannot **** the air our. Can someone offer a solution?
SOURCE: Epson aculaser c1100 cant access empty ink cartridge.
go to the reset menu (right arrow and then down arrow until reset menu is displayed) on the lcd display and then choose change toner #(right arrow until the desired toner is displayed) Hope this helps
Posted on Oct 04, 2007
SOURCE: epson stylus color 760 failing to print.
you can take it to repair shop and they will clean the head for you with some cleaning fluid if it has been without ink for a while sometimes these get blocked but it is not worth replacing cus would cost more than the printer as the ink cartridge you brought was originall then this isnt the problem check all cables if not better off buying new printer as these are not made to last long sorry couldnt be any,more help...........................
Posted on Nov 05, 2007
SOURCE: Clean "Waste Ink Cartridge" Epson R300
Had the same problem. (its a work around without removing the waste ink pad)
Took alot of work but I fixed it.
Frist thing you need to know that error means your ink waste pad is
full. Its a $75.00 to replace but there is a work around it.
You will need this free app. SSC service utitlty.
http://inkjetprinterhelp.us/epsonSSC.html Its a great app.
Instrusctions are on the website there.
You will also have to Open the access panel on the rear of the printer (remove screw) and
look inside carefullly with a flashlight. You will see a tube (down and
to your left) coming from the cleaning pump and it will have an open
end on it. This is the tube that delivers ink to the waste pad.
Use a piece of coat hanger wire or equivalent, and fish out this
piece of tube. Bring it to the outside of the printer, thru the access
panel.
Find yourself a suitable container
(Tupperware or a plastic cup or jar) that is not too tall. Put the tube
into this container and secure the tube and container so they won’t
come apart or lose connection if the printer is moved.
If you wish you can make a hole or notch in the access panel cover so it can be replaced.
Posted on Feb 14, 2009
SOURCE: Epson CX8400 ink cartridges run out early
Epson gives you a miserable 12 ml of ink. Then it reports empty when there is still 10-15% of the ink left. I saw someone set up a brand new CX8400, print a single 4x6 photo and it said he was out of cyan. I use reusable cartridges from http://www.ccs-digital.com They hold 20 ml, which is 2/3 more ink. The chips automatically reset to full if you take the cartridge out and put it back in, so you get to use every drop. The ink is in a separate container inside the main cartridge. When it's really empty, you pop out the ink tank and pop in a new one. The tanks are under $3 each. I think this is brilliant because it's like refilling only it avoids the risks and mess of refills.
Posted on Jul 07, 2009
SOURCE: after cleaning cycle ink cartridges are rendered invalid
I've had the same problem over the years and somewhere along the way came across this simple fix: when you get the "invalid ink cartridge" message turn the printer off, wait 10 seconds, turn it back on, when the screen switches from "please wait" back to "invalid ink cartridge" tap the pause button. this will somehow reset the printer and you should be good to go.
Posted on Feb 02, 2010
Aug 08, 2014 | Epson Expression XP-305 Inkjet...
May 25, 2012 | HP DesignJet 1050c plus InkJet Printer
Jan 25, 2011 | Epson Stylus Pro 7600 InkJet Printer
Feb 22, 2010 | Brother Multi-Function Center MFC-240C...
Sep 23, 2009 | Epson Office Equipment & Supplies
Jul 01, 2009 | Brother MFC 490cw Color Inkjet...
Jun 19, 2009 | Brother MFC 210C All-In-One InkJet Printer
Jan 18, 2009 | Epson Stylus C84 InkJet Printer
Mar 07, 2008 | Epson Stylus Photo R1800 InkJet Printer
May 04, 2006 | Epson Stylus Photo RX600 All-In-One InkJet...
Apr 01, 2013 | Epson Workforce Pro Wp-4540 All-in-one...
