Can"t record
Here is the complete manual for the camera. Are you sure you have all the setting correct in menu. Try to do a reset on camera. I just remove batteries and it resets. Other cameras are different.
http://gdlp01.c-wss.com/gds/3/0300000753/01/PSA470_CUG_EN.pdf
SOURCE: Canon IXUS 500 It will not take a picture the
Try to see If you can see a photo in Playback mode from your memory card (Transfer a good photo to the card first) Do all the menus display correctly? If so it would seem the camera sensor (ccd) is bad. Canon had a recall on these models with bad sensors and will repair them free of charge.
SOURCE: My Canon Ixus 80 won't seem to move into photo
changing button is not working properly either back contact is broken or whole button need to replace it
SOURCE: I have a Canon PowerShot
Some
symptoms of a defective CCD
(Charge Coupled Device) include distorted images or abnormal colors, scratchy purple lines,
blank or black pictures, and/or black videos with good sound being
recorded on the camera's flash card.
When a picture is taken, the CCD is struck by light
coming through the camera's lens. Each of the thousands or millions of
tiny pixels that make up the CCD convert this light into electrons. The
number of electrons, usually described as the pixel's accumulated
charge, is measured, then converted to a digital value. This last step
occurs outside the CCD, in a camera component called an
analog-to-digital converter.
In order to correct this issue, the repair facility needs to replace the CCD. This is not something you may do on your own; check this article for additional details: Bad CCDs. This, isn't a good new, but hope helps to solve it.
Hope this helps to solve it (remember to rate and comment this answer).
