SOURCE: wd element 250gb usb hard drive
you'll find that the external chassis is buggered, get a new one and put the hdd in and see if your info is still there.
SOURCE: My wd elements hard drive of 1 terabyte will not turn on
Usually if this happens it's either a dead AC adapter or a failed circuit board inside. If you have nothing crucial on the drive take it back to the store you bought it from or contact Western Digital for warranty.
If you do have crucial files and don't want to loose them by simply warrantying the drive, take it to your local PC store and void your warranty by having the techs there move you hard drive into a new enclosure for testing. If it works in the new enclosure buy it and be on your way. If it doesn't your problems are more severe and will require some specialized assistance from a Data Recovery Pro. If this is the case ask the techs to place the HDD in a anti-static bag then reply to me with your Country, State, City and I will refer you to a nearby Pro who can access your files and save them for you.
Hope this helps FixYa,
Chris
SOURCE: when i plug in my external hard drive, the
u need to fix your external....it has a virus thats why!.....
SOURCE: Elements by WD, AC Adapter Failed
There are replacement models for this 5V/1.5A power supply that the AD6008 uses.
One of them is made by a company called "Asian Power Devices" [APD] and their model number for the replacement for this particular unit is: DA-30C01.
I've seen them for sale on www.amazon.com for around $25.00.
Testimonial: "Thank you very much. That's eactly what I was looking for. I appreciate you speedy response."
First thing, try to change the cable, try a different one, then if it does not work, try to connect the hard drive on another computer, and changing cables as well. This will help you to narrow down the problem to find out exactly what the matter is. If the Hard drive spins properly and it does not produce any click-click sound then it is fine. If all the above fail, then you have to slave the hard drive using its internal SATA connection. You have to open up the hard drive and remove the pin that connects the hard drive to the cable. This will enable you to see the SATA connection. Slave the Hard drive on a desktop computer and see if you can gain access to it. If you can, then consider replacing both the cable and the pin that connects the cable to the hard drive. If your hard drive just spins and you can not access it while its a slave to another computer, then the hard drive has a problem.... Try the methods above, i believe your hard drive did not go this bad...
