SOURCE: I have an LG 42
When your TV (EHT) High voltage is not proper run or Power supply is not strongly create voltage.
Solve: If you repair it self,You check thoroughly.Some of components may be damage in power supply.
Check diode,capacitor or high voltage power transistor,any kinds of fuse.
SOURCE: I can't turn on my 32 inch plasma tv by LG.A green
The flashing indicator is telling you the fault. Give the number of flashes to the LG service department and they can help you with your issue. It will likely need service.
SOURCE: my lg tv will not turn on ... the red stand by
Unplug it for about an hour to let it reset itself, if it still does not work, then you will have to do more in-depth troubleshooting.
It is flashing because it may have bad power supply or it is in safety shutdown/restart mode due to shorted circuits some where. Inspect the caps in the power supply first.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
SOURCE: lg model 42pm4m plasma monitor won't turn on, red
Does the tv make a clicking noise like its trying to turn on before the tv goes into standby and the LED starts flashing? I suspect this is due to a shorted component, most likely to be in the 5V(switching) line and just want to be a bit certain before we start testing the power supply.
SOURCE: i have a LG 32LG3000 LCD TV and the power light
Tries tv unplug,replug it back like about an hour later.See,if the tv will resetting self and working again.Not.The tv power supply board it is the causes and the problems.That the board where the tv power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
