SOURCE: My Dell Inspiron 1300 wont start
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
SOURCE: Dell inspirion 530 Black sreen at boot up with blinking cursor
reinstall your windows if cannot repair windows. that is due to corrupted files in windows.
SOURCE: dell inspiron 1545 power on administrator password pro
You can get a Password Reset disc download and burn to CD. Copy/paste the address below, into your address bar of your browser.
http://pogostick.net/~pnh/ntpasswd/cd080802.zip
Download this file and burn it to CD. Put into drive and turn on PC, and boot from the CD. Follow instructions, choose the correct USER. & BLANK the password. make sure you say OK to write the data, and reboot. The logon password will now be reset blank.
SOURCE: How do I boot this Dell Inspiron 1440 in Safe Mode?
F8 at boot
or
MSCONFIG, Boot.ini tab, check safeboot (You will need undo this to boot in normal mode)
SOURCE: Dell inspiron 1545 laptop (Time- of- date clock
This could mean two things: a problem with the cmos battery or the motherboard itself. Try to remove the cmos battery first and install. If not,then replace the cmos battery.
