More than likely the regent system is needing and alternate audio source, via- analog, digital coax, optical ect... HAs it always been this way, or use to work?
chances are that it is not you operating system that is not supported but rather your sound processor. Maybe try updating your program that handles your sound. However virtual surroundsound is a joke and it doesnt really sound good at all so if i were you i would just disable it and save yourself the trouble.
The only way to get the sound from your tv/satellite is to connect the Output from your tv/satelite to the EXT Video In & Line In L / R then Select the AU Channel.
Attach a set of jumper wires from your receiver to your woofer.Check the ohms and make sure its turned on. Sync it with your receiver and this will do the trick.
OK. For all you regular Joe's like me here's the fix--plain and simple! I have Dish Networks HD receiver, an LG Home Theater System (LHB953) and an LG HD Television - although I suspect this applies for most LG TV-to-LG Audio Systems used in combination with a HD TV). My problem lied within the LG to LG setting known as SIMPLINK which tries to "auto-configure" everything between LG to LG devices.
Do this to make your HD TV (using Dish/DirecTV) play it's HD video display from the satellite provider but play the audio over the LG surround sound speakers:
1. Plug a HDMI cable from your satelite receiver's set-top-box to your HD TV. This will carry your HD "video" ONLY. Click "Input" on the TV remote until the HD video signal shows your desired TV channel from your satellite provider.
2. Plug an HD Optical cable (the one with the red laser) from your LG HTS (Home Theater System) to your satellite box. This will carry your HD "audio" ONLY.
3. This is the magic everyone seems to be overlooking. On the LG TV remote, go into the menu options and disable SIMPLINK by setting SIMPLINK=OFF. This feature allows the video and audio signals to be split over 2 different ports: HD video goes over the HDMI cable and the audio to go over the HD Optical cable.
hello there. name is ryan lets see if this helps.
typically in a combination unit there is no rca audio ouputs on the tv. reason being is it is a combo unit not meant to be a item within a home theater system. it has the whole home theater built in it. ;) however if there is any audio output jacks on the tv you should be able to wire the surround sound unit up via rca cable output from tv to input on reciever for surround sound
Typically you need to consider the surround system as the central point for sound distribution (and in newer receivers, the distribution point for video signal as well). So you need to think of your TV and Satellite as sound sources and connect them to the IN side of your surround sound system. From the back of your TV then, look for the Audio OUT (commonly Red for right and White (or black) for Left. Connect these to the IN on the back of the surround system. Likewise for your satellite box. Then make sure you select the appropriate source on the surround system. If the system supports the video signal, you can route that as well. Beware that you'll need some sort of simulation (provided by the Phillips unit) to upconvert stereo to surround ... check the manual online. If you post model numbers for the Phillips and satellite units, we might be able to direct you more specifically (provided we can find manuals online)
