eMachines W3619 PC Desktop Logo
U
Ulises Ortiz Posted on Apr 19, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Problem upgrading CPU
I've been trying to install an Intel core 2 duo e6700 on my eMachines W3619, when I try to start, everything but the power light turns on and nothing comes up on my monitor. When I put in my old processor, everything works fine I have the latest BIOS installed and flashed. Also, with the update my fans have been running at full speed and I cant find a solution. My motherboard is an ecs 945gct-m3
  • Ulises Ortiz
    Ulises Ortiz Apr 20, 2014
    UPDATE: BIOS is now updated, problem is still occurring and now my fans are running even louder than last time.
TechGirl
Level 3:
Master:
  • eMachines Master 496 Answers
  • Posted on Apr 19, 2014
TechGirl
eMachines Master
Level 3:
Master:
Answers
496
Questions
0
Helped
68699
Points
1516
Try to update the BIOS with the old CPU in, if not the new CPU could be faulty, yes I know it's new but it is entirely possible
5 Related Answers
Anonymous
  • 916 Answers
  • Posted on Feb 04, 2009
SOURCE: EMACHINE T6534 COMP. WANT BOOT . TRYING TO CHANGE V-CARDS
This could be a few things though if you have already checked the memory and HD. The next thing I would tell you is that you should check the cpu. Also make sure that everything in the BIOS is set to the default settings when you start it.
Anonymous
  • Posted on Feb 21, 2009
SOURCE: I updated BIOs and now every thing is gone.
Okay, sounds like your BIOS upgrade went south. First off, re-install the original BIOS. Usually you back up the original before upgrading. Either that, or d/l the original BIOS from emachines.com. Once you've got the BIOS working, try starting the system. I'll need to know more to help you from there.
Anonymous
  • 159 Answers
  • Posted on May 30, 2009
SOURCE: emachines won't turn on
remove the processor,ram for 30min and put them back
info2u
Nouveau IT, LLC
  • 596 Answers
  • Posted on Aug 02, 2009
SOURCE: Nothing on my Emachines computer will turn on.
I would recommend rechecking your connection to the motherboard. All wires from the power supply to board and making sure the front panel switch connection are correct. Also, make sure the power supply is compatible to the motherboare. even though a 20-Pin ps will connect to a 24-Pin board, it still does not work. Good Luck
Franklin
C2Solutions
Anonymous
  • 64 Answers
  • Posted on Apr 22, 2010
SOURCE: Emachine w3507 blue light only
If you get nothing but a blue light and no video at all it sounds like you have a bad power supply. They are easy enough to check and replace but not for a first timer. If you know someone who knows more; get a volt meter and put it on the DC scale. Unplug a power plug to a drive or find one that is not used. Measure the Yellow to black and then the red to black wires. You should get 12 & 5 volts respectively.
Intel E6750 compatible?
Motherboard supports the following processor upgrades:
  • Intel Core 2 Quad (Y) Q9xxxx
  • Intel Core 2 Duo (W) E8xxx
  • Intel Core 2 Quad (K) up to Q6600
  • Core 2 Duo E6x00 (C) up to E6700
  • Core 2 Duo E4x00 (C) up to E4400
I want driver e6700
The operating system is the "driver" for a CPU
1helpful
Cpu upgrade
Hi Keith... here is all I could find on this machine, I assume this is how yours is set up. Component details are almost impossible to get on E-machine units, they just do not provide them.
  • Processor Intel Celeron D 356 / 3.33 GHz
  • Memory 512.0 MB / 2.0 GB (max)
  • Hard Drive 120.0 GB - 7200.0 rpm
  • Operating System Microsoft Windows Vista
First, you want to check to see if your proc even can be changed; many of E-machine procs are permanently attached to the motherboard and cannot be removed; this is the cheapest way to manufacture a computer, and E-machines is bottom of the line quality computer (no insult intended, just fact). Since I don't know what CPU socket the T3604 has I can't tell you if the Intel CPU would fit it. Next, I don't know what the Northbridge is running at; if it is less than 1066 there will be a bottleneck and there is no significant gain. At this point, I suggest that you not spend a lot of money on this, better to save and build your own computer. If you are a hardcore gamer looking for high framerates you really don't want this machine. Better to load in more RAM if you have no other options. Here is something I ran across:
http://www.overclock.net/t/763634/what-to-upgrade-emachines-t3604
If I had the above details I could give you an answer.
I'm planning to upgrade my desktop and i want to start upgrading from cpu. My current motherboard is Asus P5S-MX SE and cpu is Intel Pentium Dual Core Processor E2160, 1.8Ghz. Can you give me a list of...
Oh boy, you're in the same boat i'm in with my dad's HP asus based OEM board. You're max choice in a regular core 2 duo is the E6700 @ 2.66ghz with a 1066 FSB (Front side bus). Reason being is likely identical to my situation. The board likely only supports a "conroe" core. It can't handle the "WOLFDALE", otherwise they would list higher ghz for an E6700. The E6700 is also available as a 3.2ghz with 1066mhz FSB, but its based on 45nm process, which requires different power regulation from the board. if you were to put in the wrong chip, you get nada. Not even POST errors from what i've read where others have tried and failed.
Unfortunately, E6700 @ 2.66ghz are a little rare, but they are on ebay for about 80-100 bucks, and various other places. Search for "E6700", but be careful to avoid the 3.2ghz's.
The only other choice for max is the Core 2 Extreme X6800 @ 2.93 ghz. This processor looks like its about double the cost to the E6700 though. That's a lot of extra money to get only .27 gain in ghz though, IMO, though there could be other reasons to go extreme, like availability. There might be more of them! The same logic applies here. Stay with the 65nm process, and 1066 FSB.
Here is the tech spec page for your board. Its shows all the supported processors: http://usa.asus.com/product.aspx?P_ID=fLSzpcTDJYT0rgS6&content=specifications
You might want to choose carefully on whether to upgrade this board's CPU. Might be time to scrap the whole board and get something with more FSB capabilities.
What is the fastest cpu chip you can put in the mother board
Your motherboard supports the following processor upgrades:
Like to upgrade I have DG 965 RY LGA 775 Socket
Hi, your motherboard supports several different kinds of processors. You have a choice of two for the fastest performance. You could go with an Intel Core 2 Duo Processor #E6700 that runs at 2.66 Ghz with a front side bus of 1066 Mhz and 4 Mb L2 cache, or you could go with an Intel Single Core Processor #670 that runs at 3.80 Ghz with an 800 Mhz front side bus and 2Mb L2 cache. The Core 2 would outperform the Single Core, but it is more expensive. Hope this helps! Hal
1helpful
CPU Upgrade on Toshiba L40-14H
i do not believe that cores are physically exchangeble for core 2's
1333 FSB processor ( E6850 ) on a 1066 FSB motherboard, DDR2 667 memory
Hi proenza. you're making good sence! You're D945GCL MB should be able to run 1066 FSB. Not 100% sure you're memory will keep FSB up to 1066.
Here's the trouble though. The Intel Core 2 Duo E6850 will not run on the Intel D945GCL motherboard because it is not supported. Look here at Intel's web site. Supported CPU's.
http://processormatch.intel.com/CompDB/SearchResult.aspx?Boardname=d945gcl
Intel E6850 specs sheet. http://www.dealtime.com/xPF-Intel-Intel-Core-2-Duo-E6850-Processor-3-0GHz-4MB-Cache-1333MHz-FSB-Conroe-Dual-Core-OEM-Socket-77
Intel E6700 spec sheet. http://www.dealtime.com/xPF-Intel-Core-2-Duo-E6700-2-67Ghz
This CPU is supported by the D945GCL MB.
Intel Core 2 Duo E4700 Processor BX80557E4700 - 2.60GHz.
$149.99
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3826343&CatId=2396
In order to get 1066MHz (CPU can run at), you'll also need the memory support at 800MHz. The D945GCL MB can only run DDR2-667MHz.
Many people buy a CPU to run MB's specs (1333MHz) just to find the same MB does not support DDR2-1066MHz or DDR2-800MHz. Motherboard Mfg's are lagging. DDR3-1333MHz is out there now to support the 1333 MHz CPU FSB.
http://www.lagoom.com/KINGSTON_1G_DDR3_1333MHZ_PC3-10667/KVR1333D3N9_1G/partinfo-id-580235.html
I hope this has helped you make a decision proenza.
Good Luck!
Mike
2answers
Asrock p4i65g motherboard
Your current motherboard is an mATX form factor. I recommend staying with that form factor for your new motherboard if staying with your current case. When upgrading to the new board you choose don't forget that you may need to upgrade the power supply unit also. You should upgrade to either a socket AM2+ board with dual core amd cpu or socket 775 board with Intel Duo Core2 cpu.
Top eMachines Computers & Internet Experts
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
