Need 3 digit code for controlling sony rdr-gx7 dvd recorder with my time warner cable remote.
This is a common problem for the Sony RDR-GX7 dvd recorder.
It seems to occur with various remotes (DirectTV, Bell ExpressVu or in your case, the time warner cable remote).
In most cases, the problem can be solved by using a different remote frequency from the system menu as follows:
Insert a dvd and make sure it is not playing (stopped).
Enter the System Menu then / Setup / Options / Command Mode (this can be done from the access panel on the front of the unit). There are 3 possible values, (DVD1, 2 or 3), try changing it.
Then enter one of the suggested codes for your Warner remote (in my case, for Bell ExpressVu I selected the DVD1 command mode
and I used 883 as the 3-digit code. The up and down arrows are not functional with this code but I bypass this problem by entering the menu item number. Good luck!
