FixYa Service Logo
Anonymous Posted on Jun 19, 2009
My Fixya expert utility doesn't work. Error
I get an error (oxc0000135) application failed to initialize properly when attempting to boot the fixya expert utility. It is, indeed, ironic, but any help is useful.
  • Anonymous Jun 19, 2009
    This is so ironic. Thats what I've been doing for three days now for other people on Fixya. It never even occurred to me. Thanks.
    Thanks guys, but installing .NET framework saved me. Thanks!
Arjun Komath
Level 3:
  • Master 1,170 Answers
  • Posted on Jun 19, 2009
Arjun Komath
Master
Level 3:
Answers
1170
Questions
8
Helped
439710
Points
3355
Download and install the .NET Framework from this link : http://www.microsoft.com/downloads/details.aspx?FamilyID=0856EACB-4362-4B0D-8EDD-AAB15C5E04F5&displaylang=en
A quick Google search tells me this error means you are running .NET programs without having it installed. Surf to Windows update and patch .NET layer to your system. Horizons requires at least version 1.1 I think.
Anonymous
Level 3:
  • Master 476 Answers
Anonymous
Master
Level 3:
Answers
476
Questions
0
Helped
178266
Points
1145
What service packs are installed in your system,
xp and vista both need to have thier updates installed
and the machines need to be shut down & restarted,
this will help save the new settings,
Uninstall the Fixya Utility,and Reboot. then try reinstall Fixya again
Hope this helps ,
Cheers Misterdj
Anonymous
Level 3:
  • Master 555 Answers
Anonymous
Master
Level 3:
Answers
555
Questions
0
Helped
226805
Points
1636
Try to uninstall your fixya expert utility software then restart you PC to re update  its new stteings and OS Load balancing and then reinstall again the fixya Expert Utility then let it run. But if the problem is still the same then i recommend to download the fixya exprt utility then make it sure it downloads properly then reinstall the new downloaded fixya expert utility.
If you need more  assistance just contact me.
Thanks
1helpful
3answers
Whenever i click on my c drive it shows hmwfln.exe application error. application failed to initialize properly 0xc0000005. when i click d drive it shows hlgajw.exe application error 0xc0000005 and on e...
0xc0000005 error is one of the errors a PC user can face. This is a critical access violation error that needs a quick response. If this error is not addressed immediately, this problem might destroy the computer system. Because this error relates the computer memory, there is a huge tendency that you are going to experience computer freezes and slow down. The Windows operating system will run slow because of some system defects.
Yahoo messenger will not even attempt to come on. All I get is a window that says YahooMessenger.exe Application Error Application faied to initialize properly(OxcO150002)
The error clearly says that the application is having problem so it couldn't be opened or run. Your only option to repair the Yahoo! Messenger or to re-install it (both a more or less similar). First of all, download the yahoo messenger and then install it, once everything is done correctly, it should work properly.
Please follow this LINK for the instructions on how to download and install it. Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
6helpful
2answers
The application failed to initialize properly (0xc0000135).
When attempting to run Microsoft .Net based applications, you may get the following error on startup:
The cause of this error is that the Microsoft .Net framework is not installed or is damaged in some way. Therefore applications will fail to launch.
To fix this error you can run Windows Update and find the Microsoft .Net framework update to install. Alternatively, you can download the Microsoft .Net Framework directly from Microsoft.
1helpful
THE APPLICATION FAILED TO INITIALIZE PROPERLY (OXC0000135) CLICK ON OK TO TERMINATE THE APPLICATION. CARD STUDIO 2008 DELUXE
Try to re-install the software, else create a new short cut for that application from the applications folder like creating a short cut, maybe the problem is with the application shortcut.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
4helpful
3answers
The application failed to initialize properly (0xc0150002). click ok to terminate the application. yahoomessenger.exe - application error. the application failed to initialize properly(0xc0150002). click...
I'm having the same problem, not quite sure whether it is happending due to upgrade to IE 8 or Windows Installer 4.5 installation. Cleanup and re-install of Yahoo Messenger 10 won't help. The YahooMessenger.exe fails to initialize right during the installation process.
STUCK ON LOG IN NOTHING MOVING LEFT OR RIGHT CLICK SCREEN SAYS ERROR IN APPLICATION FAILED TO INITIALIZE PROPERLY 0XC0000005 ISASS.EXE/APPLICATION ERROR
I'd try booting windows into safe mode and disabling windows firewall then trying to boot up normally. I've also heard this may be some kind of a virus.
Application error for GoToMeeting
Thaire765: Please give us a call 24/7 at GoToMeeting support and we'll help you solve the mystery.
2helpful
Hello fello fixya experts my expert utility was working just fine untill today i tried to log into it it and this is what it said an unhandled exception has occured in your application if you click...
Yes this problem has been resolved
i had the windows enterprise suit pop up on the computer just before this had happned and it was conflicting several of my programs I couldnt even run any type of scan so i forwarded the problems to my hewitt packard live team and they ran a scan using malwarebytes and got rid of a rouge virus and several other viruses that had attached to several programs they originated from google search engines is what hp told me and my fireforx never even caught it but any way i am now virus free and good to go and my expert utility is now working great
2helpful
FixYa Expert Utility Issue....(",)
your firewall might be blocking the connection to the site add a exception in your firewall settings
2answers
Error message on laptop boot up
You need to reinstall the modem driver ..
Top FixYa Computers & Internet Experts
ZJ Limited
ZJ Limited
Rob Hill
Rob Hill
Grand Canyon Tech
Grand Canyon Tech
Are you a FixYa Computer and Internet Expert? Answer questions, earn points and help others
