SOURCE: How do I remove the battery door from my ixus 75?
hi..
1. Turn your device off and remove the battery cover and battery
2. Remove the end-cover by pushing the cover away
3. Pull the bumper tabs up to separate the bumper from the device and remove bumpers
4. Snap new bumpers firmly into place
5. Re-attach the end-cover, re-insert the battery and re-attach battery cover..
thank u
rate me!!!
SOURCE: I have a Canon power
Unfortunately what you have described indicates that there is a problem with the main circuit board.Make sure that the battery is fine.Clean the battery connector with a cleaning solution as dust and dirt could cause this problem. You could try :-
1. Remove the battery and memory card from the camera.
2. Let the camera sit with the battery and memory card removed
for approximately 20 minutes.
3. Reinstall the battery and power on the camera. If your camera still
doesn't turn on, unfortunately, your camera will require service to
correct the problem.
Note - On most occasions the cost of repair is quite high as compared to the cost of the product and investing the money in the new camera is a wise option.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
SOURCE: My Power Shot SX130 IS
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
SOURCE: need to replace battery door on canon sd400 camera
I have the exact camera. Spoke with a local camera repair shop. They had to send it back to the factory for the part and installation and am waiting for it to be returned in the mail.
