HP Compaq nx6110 PC Laptop Logo
Posted on Jun 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My asus a6000 doesn't seem to notice it's internal speakers
I can't listen to anything except for that annoying beep from the system device. I have the drivers (possibly not the right ones) but i got the laptop secondhand. after about a year or so of reliable service it had been hit with a virus. So naturally, i reformatted it.
The problem is that in the control panel it says everything under audio devices ( codecs, drivers, etc) all are working properly, however when i go to the devices pane my laptop says there isn't any recording OR audio playback devices.
On top of that the headphone jack doesn't do me justice either.
No audio, whatsoever.
WHAT IS GOING ON?!
Will accept all help
Cheers
  • nathanwharer Jun 19, 2009
    True, true... yet i'm not sure which driver is the right one for an asus a6000. I don't have all the right ones since i never was given the recovery disc so i've looked up countless sites and downloaded driver robot and driver detective so not quite sure where to go for proper asus a6000 drivers..?
    ooh, this is relevant to my interests...
    i haven't tried this yet so will do, just xp on my comp
    cheers!
Anonymous
Level 2:
  • Expert 98 Answers
  • Posted on Jun 19, 2009
Anonymous
Expert
Level 2:
Answers
98
Questions
Helped
79767
Points
281
Well I, generally reboot my comp when this stuff goes wack. I'm guessing you tried that. Also, let it stay off for a while. Try reinstalling the driver, updating the driver, and/or downloading a new one. Please rate, if I was helpful.
  • Anonymous Jun 19, 2009
    http://driverscollection.com/?H=A6000 Series (A6G)&By=ASUS
    See if that's one you've used, and what version? Vista, xp or less?
    Let me know how the situation unfolds. Thanks!
ASUS A6m A6000
Don't really understand this... is this a questions or a statement.
Please define in details you the fixya community can help you!
Cheers!
P5KPL-AM speaker beep
Hello, I am the technician that will be assisting you today. My name is Norman-Wynne Damstra.
Welcome to Fixya, Sadael.
Yes some-times the case/computer chassis does not have an internal BIOS/CMOS beep code speaker built in.
So what you will need to do is go to your local computer store and purchase a mainboard beep code speaker. You may even find it online at your favorite computer store.
The modern speaker is very small compared to the older mainboard beep code speakers.
Your computer will continue to work without the speaker, the beep code speaker is there to help diagnose/troubleshoot problems when they occur.
Take care!
2answers
5helpful
3answers
I can listen to sound using my earphones on my Dell Optiplex GX520 but cannot hear anything through the internal speakers otherwise. How do I turn them on?
the internal speaker is only for beeps. These beeps are constant or short and only happen when the computer is trying to tell you how its about to die lol.
Buy some speakers. I would highly recommend a 2.1 system from logitech.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010370060%2050001080%201090608149&bop=And&ShowDeactivatedMark=False&Order=PRICE
2answers
Motherboard will not post
Turn it off. Remove the AC power-cord.
Disconnect all the devices (floppy, disk-drive, CD-drive).
Remove any add-on PCI cards (modem, network, TV, 2nd video).
Remove ALL the RAM.
Reconnect the power, and turn it on.
Try to POST -- if it is not "dead", it should "beep" a few times, due to having _NO_ RAM installed.
Turn it off.
Add ONE stick of RAM.
Connect the AC power-cord.
Turn it on.
Same "beeps"? Different? No beeps?
Same problem, extremely annoying
Go to Speakers properties > levels > mute pc beep.
That should stop the annoying power beep but not the startup jungle.
Regards.
Logitech X-530
you need to go into the bios of your machine turn on machine tap del key bios comes up do not do this if your not computer ok. you can screw this up further
M2a-vm mother board
Hi auriaskate,
Currently you are using the onboard PCI video adapter. This graphics adapter uses you're system memory to function.
If there is a problem with you're system memory the beeps can lead one to think there is a problem with the onboard video.
You can not remove the onboard adapter so there may be a problem with you're system memory. (I doupt you're memory is bad) but on the other hand it might not be fully installed correctely. Power off the PC & unplug the power cord from the PC.
Please remove you're system memory & firmly reseat it.
Plug the power cord back in. Start the PC & listen for any beeps except the 1 normal beep known as P.O.S.T = Power on self test. Any beeps after that there is a problem with a device connected to the board.
You're Asus M2A-VM uses an Award bios. Click on the link below to see what Award beeps mean.
http://www.bioscentral.com/beepcodes/awardbeep.htm
Try the memory reseat & check. Let me know if this helped.
Mike
4helpful
3answers
Small black device within RCA RP5420
That black disc is the "backup" alarm if you lose power.... The battery then takes over and "buzzs" throught that little speaker too wake you... even tho there is no power... Mine buzzes too... cut that little speaker outta there.!
Robert
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
