SOURCE: can't upload songs on my ipod
i have the same problem. i tried everything but nothing worked .. sorry
SOURCE: how to insert songs/movies in 80GB apple ipod classic
Just few steps:
Please rate my solution.
Thanks..
SOURCE: ipod nano 2g white cannot detect to pc
When you connect your iPod to your computer, does the iPod itself change to saying Connected or Do Not Disconnect? If not I would recommend putting the iPod into disc mode. After it is disc mode you will need to restore the iPod using iTunes. Below is a step by step on forcing an iPod into disc mode as well as restoring. Please feel free to comment any questions or concerns.
Putting ipod into disc mode
http://support.apple.com/kb/HT1363
Toggle the Hold switch on and off.
(Set it to Hold, then turn it off again.)
Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect".
After a few moments, your iPod will appear in the Source panel in iTunes.
Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software.
The 4 possible restore options are:
Restore Option
1: Restore - Restores with same iPod Software version already on iPod.
Restore Option
2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.
Restore Option
3: Use Newest Version - Restores with the latest iPod Software available.
Restore Option
4: Restore and Update - Restores with the latest iPod Software available.
If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
A progress bar will appear on the computer screen indicating that the first stage of the restore process has started.
When this stage is completed,
iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring.
Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models).
During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display.
It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage.
Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to
name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
SOURCE: restoring an ipod
Make sure you got the latest itunes version and latest ipod classic version. Also you need to be on the original computer you used to sync with the ipod. Open up itunes and connect the ipod. Your ipod should show up on the computer. Just click on the restore itunes back to factory default button and you should be g to g.
