Control Panel Light is out.
I'm not sure if you have removed the trim on the right and left front. so if you have not then open the bottom oven door and in the lower right and left corner near the hing should be a screw, remove them and pull down on the trim pice and now this will revial a screw at the top right of the control pannel on the left and right , now remove them screws and make sure power is turned off at the fuse box and lift on the control pannel. if this does not work you will need to remove the unit.
