SOURCE: water in refrigerator door coming out slow
Hi Ben22 Sounds like some thing pluging the water line or the water line pinched some where.. if the hole was 1/4 inch you should get enough water with that big of a hole. I would check the water line for a obstruction. Let me know if this helps. Krazytech
SOURCE: freezer does not make ice
You need to check and see if ice maker has any water init. if not check the fill tube that goes thru the back wall for stoppage while you have it out rin the maker thru a harvest mode and listen for the sounds of the solonoid opening. If tube is full you'll need to replace the slow leaking valve a common problem. for parts call 704-819-6557
SOURCE: Bad Water Taste from Refrigerator
I ended up looking at trhe bottom of my resevoir tank and noticed a black soot. I ordered a replacement tank and tuibing from GE and replaced both of them. When I removed the tank and poured the water from it into a glass, it was absolutely aweful. I never had it tested but assume it was a fungus or bacteria. Like I said, it was this way from the first day I installed the refrigerator. Since I replaced the parts, the water has tasted perfect!! It was simple to replace as well. Much cheaper to do it your self than jire a tech.
SOURCE: whirlpool refrigerator ice dispenser no longer workds
Ok, I show parts that are available for that model, sounds like the control board is defective for your dispenser, or possibly the Ice maker control board. It also could be a break in the wiring or the control itself. Below is a break down for those parts, wiring and the control behind the push to dispense ice or water. Hope it is not that control because some places don't provide that part. Now if it's a connection problem that we can find, I will do mu best to help you solve this.Could you insure the model number is correct as this is very important? [email protected]
