There is a problem with the drum catching and I need to get it out
SOURCE: ariston awd 12
Click on your model number (below FIXYA) on this website, & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, u hv your manual on line. If available that is....................
Rate me pl if helped...................
SOURCE: Ariston AWD 121 wont work
make sure the water supply is turned on , a small red and blue tap usually under the sink
SOURCE: I have the error code 5 on the Ariston washer
hello,
what this mean is that the error code 5 indicates that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F). in your drying machine.
thank you.
