Panasonic KXDT333   Phone Logo
A
Anonymous Posted on Apr 17, 2014
Incoming call numbers are not the showing on the sreen
Incoming call log numbers not showing
2answers
One Panasonic KX-T7633 Phone Not Showing Caller ID
What did you dial when checking voice mail?
How do I access the call log in this phone? Nokia M7310
No, they are not turned on by default. They have to be programmed in system programming. Once they are programmed, a soft key will show CALLS. Pressing this soft key will display the log.
How do I get the Panasonic KX-T7633 to show incoming caller's phone number? Is this a feature the phone automatically has or do I need to contact my telephone provider? Thank You.
You need to have Caller ID enabled by your telephone provider. Most providers charge a fee for the service. (In my area, it is $4.50 to display just the incoming number, $6 for names and numbers or you can get it in a bundle with other services for ~$10. Your prices may vary.)
The incoming calls will be listed in the call log once the service is active. You can clear this information when you are confirming the log information after navigating to the desired item by pressing Clear. You use the left/right arrows to find desired log/directory and then the up/down arrows to select a log.
I hope this helps.
8helpful
2answers
No number or contact name on incoming call.
Hi, I had the same problem few days back. I am using Nokia N95 with a Vodafone service. Any call I receive simply showed "Call" and on checking the call log, says "No Number". this problem is not with the phone, but with the network. I checked with the Vodafone customer associate, I got to know I din't submit my documents to them which is required on an yearly basis and so my phone had this problem. So if u r also having same problem as I had, try contacting ur network service associates and they could help you fixing the problem.
Remove message of the middle line of display
Pick a spare button and label it CALL LOG. Now press PROG that button and dial 54 STORE. Ooh, it should light up. Now press it and your display will show 3 of the 4 lines of CID info from the calls to your set. The navigator button will show the rest, just keep pressing the UP, DOWN, LEFT, RIGHT buttons. When you run out of items to display, the light and INCOMING CALL display will go out.
If you press 54 and the 3 digit number of your incoming call group (maybe 601 by default) it will follow the incoming calls to the entire call group.
Carl
1helpful
Nokia 6650 flip phone will not show contact name on incoming call
Make sure you have the incoming number in your address book. If you don't only the incoming number will show up.
2helpful
How to do check my missed call log
A Panasonic TDx system has 2 types of call logs, one personal for the set, and one for the ICD group.
Pick a spare button, press PROG, the button, and dial 54 STORE.
If you had incoming: 00x on your display, that button will light and you can now press it to see who called. Your Navigator UP/DONW key will step you forward or backward through the log. The LEFT/RIGHT key will display the 4 lines of the display if you're not using a 7636 phone.
If you want to see incoming calls to a particular ICD group, pick another button, and dial 54 plus the ICD group number. For example, I used 100 as my ICD group (now 600 by default). I have 2 buttons, one logs my extension calls, one displays the system calls.
Carl
2helpful
2answers
Display showing "Incoming Call :001"
Don't worry, if you ignore it will grow :-)
It's a count of the unanswered calls with CID. If you take a spare button and program it for Call Log, it will light up and you press it to start the call log display.
Try this press PROG 54 STORE
When you press it, your display will now reveal the numbers under incoming.
If you put a number after the 54, it will log calls for a particular group. I get my calls on incoming group 100, so I store 54 100 under a button and I can see all system calls. I have a second button for just my extension calls.
Carl
Top Panasonic Lands Phones Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
