There are 2 easy ways to transfer contacts from palm phone to iPhone. Check the below instruction.
Solution 1. Using SIM card Directly
If the Android users haven't cut their SIM card for iPhone yet, they can take advantage of the SIM card to transfer contacts from Android to iPhone. Android users need to go to their Contacts app and choose Export Contacts to SIM. Then the contacts can be transferred to the SIM card. Now users can cut the card and install it in iPhone, and go to Settings > Mails, Contacts, Calendars, and scroll down to find Import SIM Card Contacts. Now you are able to import the contacts from SIM card to your iPhone.
Solution 2. Using Gmail
Another method is using Gmail. Android users can take advantage of Gmail (or other emails provide contacts sync function) to sync Android contacts to iPhone. The following tutorial will show you how to do it:
- Log in Gmail on your Android phone, and check the "Sync Contacts" option (If you are first time to use this method.
- After Gmail Contacts synced with your Android Contacts, you should turn to iPhone, and tap Settings > Mails, Contacts, Calendars, and tap Add Account. Then choose Google, and enter your Gmail account.
- After adding Google Account, you can turn on Contacts, and iPhone will ask whether you want to merge with your iPhone contacts. Click Yes and the contacts will be synced to your iPhone.
With the sync function of Gmail, people are able to transfer contacts from Android to iPhone with ease. If you aren't using Gmail on your iPhone, don't worry, you can take advantage of other email services like Yahoo, Outlook and so on.
For more methods, check:
How to Transfer Contacts from Android to iPhone
