How to turn off the shutter noise?
Thank you
1. Press the menu button, then navigate across the top of the screen using the four way pad to the tool icon and select it.
2. A new set of menu options appear, navigate across the top of the screen to option 3 and then down to the item labelled "Shutter FX" and press select. Using the pad, navigate to "OFF" and select it.
3. Press the menu button to exit and you're good to go.
Note that on the same screen you used to silence the shutter there are other settings which you may wish to adjust. Note that using the option to turn off audio signals does not affect the shutter or focus confirmation signals; you already know that there's a separate option to adjust the shutter noise, and you'll notice that the same goes for the focus confirmation noise. The volume control affects all noises and I've set it on mine to low.
