Question about Panasonic KX-T7730 Corded Phone
KX-T7730 Time and Date
My phone always displayed the Time and Date and today it will only display my extension. How do I get it to display the time and date again?
  • Panasonic Master
  • 2,460 Answers
Walk up to the phone and don't touch anything but the * button. Keep pressing it and watch the display. Now you now the 3 states of the button.
Carl
Posted on Jun 19, 2009
6ya staff
SOURCE:
HOW TO SET DATE AND TIME
You need to set the date and time from the default extension "the programming extension" normally extension 20 or 21. You need to enter system programming mode - refer to user manual, then once set, all handsets should display the correct date and time.
Sep 23, 2013 | Panasonic KX-T7730 Corded Phone
I need the directions to set the time and date on Partner 18D phones and how to set up extentions
Changing the time on a Partner system is done on either ext 10 or 11. At one of those ext's press the feature key and "00"
next press the left hand intercom twice
the display should say system programming
enter in "#103"
the display should say system time and the current programmed time
enter the new time in 24 hour format
To change the date enter #101
the display will say system date and the current programmed date
enter in the new date in MMDDYY format
press feature "00" to logout
As far as setting up the extensions, I'm going to need a little more specific info to help.
Aug 26, 2010 | Lucent PARTNER18 Corded Phone
Panasonic KX-T773 reads "102:" instead of date/time
Your extension reads 102 because that is the extension #.
Press either the tranfer key or the " * " star key and your display will change to time and date or just the date.
Oct 28, 2009 | Panasonic KX-T7731 Corded Phone
Intercom issue
Those are 2 very different questions. Since you both have display phones, look at them. A 7731 on a TA system changes state with the * button. There are 3; Extension, Time, Time & Date.
When she calls you, your Auto Answer button is probably lit. Press it so it turns off and haver her call you again. It should ring, but not always. The button can control a couple of things, according to programming. Now, have her press her AA button until it lights. Now call her. Voice call?
If none of this works, please provide your cabinet model number. It's listed on the side of the cabinet where all the phones plug in.
Carl
Jun 09, 2009 | Panasonic KX-T7731 Corded Phone
Avaya 8434DX Display won't show date and time as normal display
You should be able to hit the Menu button, then the arrow directly below the TmDay display and then hit exit once the date and time are displayed. The date should disappear but the time should stay.
Feb 12, 2009 | Avaya Definity 8434DX Corded Phone
Making the date and time show after the phone rings.
Sounds like you have several issues here...Time & date is set by entering the DB Administrator, then using the code 08-14. Feature69 defaults a set, not the time. The incoming display is normal, as you are a member of the first UCD group. When you pick up the phone, it shows ICM because you are in intercom mode. There are 3 different ITCM modes: green, red, blank. Your extension button lights red because it's an indicator that you are on the phone.
Jan 16, 2009 | Comdial 8324S-PT Corded Phone
Lost the time and date line in the display
Unplug the phone, wait one minute, then plug it back in and see if the display comes back on. Press the program button, press 22 on the dial pad, press program button again ( if the phone is ringing on the incoming call and not just flashing).
May 31, 2008 | Panasonic KX-T7630 Corded Phone
Panasonic KX-T7456 Corded Phone - Date & Time Display
The display on the phone ... to change back and forth between the date and time, and the extension information, press the "star" (or asterisk) key while the phone is on-hook, this will toggle the display back and forth.
Hope this helps, David B.
Mar 10, 2008 | Panasonic KX-T7456 Corded Phone
Changing date on Panasonic KX-T7731
If it is displaying "101:" that is your extension. You can press the * key (with phone on the hook) to scroll your display through date and time formats and to display your extension.
When it says "PITS-PGM NO" you will need to press one of the buttons on the numerical key pad to choose a function to change.
Hope this helps!
Feb 07, 2008 | Panasonic KX-T7731 Corded Phone
CHANGE THE TIME/DATE AND TURN THE RINGER ON
You have to use the feature 9 # from the administrators phone (usually extension 100)
Go to extension 100, press "feature,9,#" and you'll see the numbers on your display blinking like a digital alarm clock. Enter the time and then press feature to complete.
Oct 11, 2007 | NEC DTU 8D-2 Corded Phone
Panasonic KX-T7730 Corded Phone Logo
846 people viewed this question
Top Panasonic Lands Phones Experts
Ekse
martin hogg
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
