Even at the lowest setting, my fridge freezes all liquids. I've defrosted it, but that didn't help.
There is a motor with a flapper that opens and closes to keep your temp correct in the refrigerator side most likely the motor is bad and stuck open so your air from the freezer has constant flow to the refr side. the flapper is in the back of the refr behind a cover where the air flows in.
Anytime your products freeze in the refrigerator milk tea soda even at the lowest temp setting replace the thermostat /sensor given time everything else will freeze
Also your ice cream will be rock hard excessive run time
Its either a bad defrost timer not kicking on, bad main control board or the temp switch. Sorry not much help but the only way to really tell is check with a ohlm meteor and eliminate each part.
source
https://zanussi-repair.com/
Thanks for the suggestion. However, this is a mini-fridge and there isn't a motor or flap between the freezer section and the main fridge. Again, it used to be fine, but now it freezes liquids no matter what temperature it's set at.
