Replacing Ink CartridgesMake sure you have a new ink cartridge before you begin.
Caution:
Do not open ink cartridge packages until you are ready to install the ink. Cartridges are
vacuum packed to maintain reliability.
Leave the expended cartridge installed until you have obtained a replacement, or the ink
remaining in the print head nozzles may dry out.
1. Turn on the product.
2. If an ink cartridge is low or expended, you see a
message on the LCD screen indicating which
color to replace. Press OK.
If a cartridge is expended, you must replace it to be able to print or copy. If a
cartridge is low, you can continue printing until a cartridge needs
replacement.
If you're replacing a cartridge before you see a message on the LCD screen,
press xMenu, press u or d to select Maintenance, and press OK. Then
select Ink Cartridge Replacement and press OK.
3. Open the scanner, then open the cartridge cover.
4. Squeeze the tab on the cartridge and lift it up.
Dispose of it carefully. Do not take the used
cartridge apart or try to refill it.
Warning:
If ink gets on your hands, wash them thoroughly with
soap and water. If ink gets into your eyes, flush them
immediately with water. Keep ink cartridges out of the
reach of children and don't drink the ink.
5. Before you open the new cartridge package,
shake it gently four or five times. Then remove
it from the package.
6. Remove the yellow tape from the bottom of
the ink cartridge.
Caution:
Do not remove any other labels or seals, or ink will
leak. Do not touch the green chip on the front of
the cartridge. This can damage the ink cartridge.
7. Insert the new ink cartridge into the holder
and push it down until it clicks into place.
8. Once you replace all the cartridges that need replacing, close the cartridge
cover and push it down until it clicks into place.
9. Close the scanner.
10. Press OK to begin charging the ink. This takes
about 2 1/2 minutes. When you see a
completion message on the LCD screen, ink
charging is finished.
Caution:Never turn off the product while ink is charging or you'll waste ink. If you see an inkreplacement message on the LCD screen, press OK and press down all the cartridgessecurely. Then press OK again. If you remove a low or expended ink cartridge, youcannot reinstall and use the cartridge.
See
Page 47 in manual
Download Manual Here
I dont know how to change my ink cartridge.
Have 5200 Epson printer scanner-firml stuck cartridge is wedged in-do I remove the 2 screws holdeing the 4 cartridges in?
my cartridge keeps shooting under the right hand cover too although my printer is a stylus c40 plus - i've just replaced the colour cartridge and it still won't print do i have to replace the black one too?
i have the color ink catridge stuck in the black carttridge it wont come out and im at work!
Can't get the to the ink to replace them
