Power outage when pwer came back on green light was flashing
I would suggest trying to replace the power supply. If that does not fix the issue, i would need to hear more about the computer.
SOURCE: sony KDF-E50A10 50 in. HDTV stays on for 25 - 30
Hi, Lamp of TV getting weaker and requires replacement. This shut off by itself will increase day by day until you put new lamp in TV. Always Buy Sony original lamp and avoid aftermarket/ cheap lamp for TV safety.
SOURCE: not powering on after power outage
Sometimes after a power outage, some power supplies can take a hit but will not provide the needed voltage to operate your pc. In this case you should replace the power supply. For future protection, connect your pc to a power strip or power source with surge protection. This will range in price from $7 to hundreds depending on how much you need to protect and your budget.
Good Luck
C2Solutions
SOURCE: ps3 power wont stay on
search yellow light of death on google
1)Turn off your playstation. If you think your ps3 has been
caught by the heat, then wait at least 20 minutes and put it back on
again
2) Check if there's any loose cable.
3)
Try to put out your playstation's hard-drive, and put it back in. You
might want to repeat this 2-3 times for better results.
If this
did not work send to sony to get fixed
the problem on you tv is the fan is not working this is the big fan you see on the back of your unit , is very ease to replace take cover off and you would see the fan , when you look the tv from the back look at you left and there is , you may want to call sony that way you would get the right part , i have fix a lot of this tv with this problem
