I installed a new battery and the machine responds with a beep, but when I try to enter the set up for the menu, it does not respond.
SOURCE: GE Microwave displaying --F3--
F3 on a GE / Hotpoint
microwave means you have a shorting keypad / controls.
There's a chance it can come on by itself and run unattended, which can result in a fire.
So until it is repaired,
please leave it unplugged or leave the door
open.
On this model, the keypad is not available as a separate part, so you would have to replace the entire controller assembly.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
Then you disconnect the wires and install the new controller.
You can order part number WB07X10903 here for $114.37 (compare that to $174.75 direct from GE!).
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
CAUSE: Initial settings did not take when programmed.
SOLUTION: Time and date, telephone and ADF serial numbers need to be reentered:
1. Sub-power ON g Utility/Counter g Machine Admin settings g System settings g Date and time setting g (Enter year/month/day/time) g OK g Exit g Power OFF sub-power switch.
2. Enter Service Mode g System settings g Setup date input g (Enter year/month/day) g OK.
CAUTION: DO NOT POWER OFF. Leave machine in Service Mode.
3. In the Service Mode g System settings g Telephone setting g (Enter 16-digit number) g OK. Repeat for the fax number. Set to all 9s if there is no fax number.
4. In the Service Mode g System settings g M/C serial number setting g touch ADF g (Enter ADF serial number) g OK g Power OFF sub-switch.
5. Power ON sub-switch and run copies with no security lines.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
