Nokia N95 Cellular Phone Logo
Posted on Nov 01, 2007
Recieving calls when recieving a call theres no contact name shown just CALL but when recieve a text message it shows whos sent it? got contacts in memory card and in phone memory and in sim card but still comes up with CALL when recieving a call and not the person ringing WHY please help
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Nov 16, 2007
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
0
Helped
298
Points
5
When u have the name stored both in phone memory as well as sim memory this happens. try removing any one.
Can't display the senders name in my inbox
i faced this problem too....please go to contacts -) options-) settings-)
change show contacts of....both sim and phone....add contacts saved to phone memory....
tip
Cant send or recieve text messages on my mobile phone
hi, if you are having trouble sending or recieving text messages then the fisrt thing you need to do is delete all the sent and recieved messages and also drafts due to the fact that if your memory is full this will give you loads of problem sending and recieving text or mms messages so deleting these will then get your messages working again.
If how ever you still cant send or recieve text messages then the chances are that your message center number is wrong or got mest up, what you need to do is contact your service provider and ask them to send you the text message center number settings, they will then tell you the correct message center number and how to change this setting on your phone.
They wont charge for this and it will only take 2 minutes to solve your problem.
on Dec 03, 2009 • Cell Phones
Contact names doesn"t shown when
Try to check your phonebook for double entry (2 names with the same number). Remove at least one.
Please rate me if this helps.
I68 sciphone can't recieve or make call or txt messages
try putting a 1 then area code then number.
(13215556666) this will also help with contacts names showing up when you rcv a call or text instead of just a number.
good luck
2helpful
Wont recieve texts
u need to set the messege centre number correctly contact ur operator helpline or try deleting the messages in your outbox and saved items.
When i recieve a text message it show the number and not the name of sender
this is because you have a duplicate contact name in your phone book.. if you have different contact name in your phone book with same number.. only the number will show up...
2helpful
No caller name jusy their number when recieving a text
go to ur message settings and set the phone caller id on and press ok after some time when any message come from ur contact numbers it will show or it is unkonwn number means it will not shown
May 22, 2009 • Cell Phones
Phone wont send or recieve txts
On every phone there are settings that can stop you sending texts. However all phones should still receive texts even if all the settings were changed. As the text message is directed to you mobile number you should still be receiving?
When you compose your text and select contact does the phone move them to the out/sent box?
Settings to check for sending are your 'message centre number' (your network provider can supply and they are normally different for pay monthly and pay & go) 'Message sent as' should be 'text' (not fax or email etc).
Text problems are common where people change or delete digits from the message centre number by mistake.
If you cannot receive texts i would recommend speaking to your provider for help as it may be your account details at their end? (beyond your control). Hope that helps?
Apr 21, 2009 • Cell Phones
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
