SOURCE: suspect drum bearings
most lg front loaders have the plastic outer drums which have about 16 h/duty screws holding the two halves together. extreemly tricky to strip to gain access to inner bearing and seal. Th/stat, motor, piping and other items have to be removed and dissassembled to enable drum to be removed. that repair i suggest for a service repair.
SOURCE: drum bearings
Removal of the front seal (just the side right next to the door needs to be removed) is a spring loaded wire. There is a special tool for it, but it can be done without the special tool. Other than that, mostly phillips head screws and a few metric bolts. The suspension shock absorbers have a tab you need to depress to push them out.
SOURCE: replace bearing
You can try a puller but typically it is recommended to replace the entire rear outer tub half (which comes with the bearings already pressed into it). You will also need the tub seal that goes between the front and rear tub halves. Hope this helps.
SOURCE: drum bearings replacement
go to this site...
www.Howthingswork.com
it is amazing what you can find there
SOURCE: Need to replace bearing in lg 2277hw washer.
I think that this might be the issue with mine also. How did you come to that conclusion on yours? I really do not know what to do at this point.
