Could be the fuse in the back turn off the power and trace the wiring with a multimeter, when you stop getting continuity there is the fuse.
Good luck Ray
My guess is the element in the back of the oven took that moment to die. You will have to get an appliance engineer or good DIY electrician to check the supply to the element to be sure. While you have it out you can write down the serial numbers etc off the label on the back. You will need them to purchase a new element. Just go online to an appliance spares specialist.
Good Afternoon Friend, thank you for allowing me to assist you!
I understand you are experiencing an issue with the oven of your Frigidaire range. May I have your model number please? You can normally locate the serial tag (which provides your model number) in the storage drawer, on the right side. Also, think about what may have happened prior to this occurrence. For instance, did you notice any strange functions or any other error codes prior to this issue? Do the burners/elements work? With this information I can assist you better in pinpointing the problem.
Meanwhile, let's try resetting your range by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait approximately ten minutes and then turn your range on. If resetting the power does not correct the issue, could you please advise me if the issue continues or provides an error code. Thank you! -Z
If element caught on fire, I would suspect stove needs cleaning. Do that then elements should not smoke for long. (I hope all moisture was removed from stove!!!)
Buy a new stove element. If you open the stove look in the back. It should be black. It might have a crack or be clearly broken. This is a cheap fix. If you want to be sure that it is working at the connection unplug the element and pull it out. Put a volt meter into the prongs. Turn stove on and see if its putting out voltage.
Had the same problem after overusing one of the bigger elements on my bellini induction stove / cooktop to boil copious amounts water. Element eventually stopped working and would just flash power level similar to when it cant recognise an induction pot, but also made a clicking noise over and over. My solution was to turn mains power off at meter box, and back on to reset the stove. When power came back on stove was working again! might have reset some sort of cutout sensor inside stove but cant be certain. Anyway, worked for me so give it a go and see if it helps. good luck.
I work on stoves with various problems all the time, and have never encountered a problem exactly like yours. You may get other answers, but here's my two cents worth: When I don't trust a stove, I replace it. Period. Hopefully, your's is old and you're ready for a new one. A new stove is much cheaper than a house fire.
