Want to change the name on the device
SOURCE: Samsung iDCS 28D Voicemail Problems
If you have administrator access use the following steps to change the code:
Access the Administratin Main Menu and select 4 for mailbox programming.
Select the mailbox to program. Dial option code 1402. The current value will be played. To hear the current value press 1, to enter a new value press 2, to hear the range of valid values press 3. Press 2 to enter new value. Enter the access code for the mailbox. The value you entered is played back. Press1 to save or 2 to re-enter. Press 3 to exit without saving. Press # to exiit or hang up.
SOURCE: I have a Samsung iDCS
Regarding "Same Problem": Probably said "unavailiable CBT"? In that case it's because a call button hasn't been programmed into the keyset.
SOURCE: I have the samsung IDCS
Hi, all you need to do is to go into your voice mail via the voice mail key, once in listen to the prompts until it says ' to assign your no answer greeting'. The prompts give the option to listen and record a greeting, however make sure that you delete the original and record a new greeting other wise the messages play back-to-back! I've posted a video to help you to do this, or visit www.abbeytelecom.com for further advise
SOURCE: how do i change my voicemail greeting on my
Hi, to change your Voice Mail greeting press your Voice-Mail key, enter your passcode, press 0 , 5 , 7 listen to your greeting, press 3 to delete and re-record your message. when you have done this press the # key to save. I have sent you a Voice Mail training video, i have over 65 others like it giving help and advise on the Samsung DCS.
http://www.abbeytelecom.com for written copy
