There was a pop then it stop working it the breaker outside it worked for a minute and stop working
If you are saying that the breaker in the breaker box has been tripped, then there is a problem with the circuit or in the stove. The circuit may be checked with a volt meter. If the problem is in the wiring circuit, the breaker will trip with the stove unplugged. The problem is most likely in the stove, and the stove's wiring needs to checked. If you are unfamiliar with 230V wiring and how to safely test the wiring, have an appliance technician service the stove.
SOURCE: GLEB27T8ABA Frigedare Double wall oven electric
check the fuse/breaker for the bottom element
SOURCE: f7 error steady beeping
short inthe key pad, thinks a button is being preesed for an extended period of time youll need to replace the keypad/ electronic control
SOURCE: GE Advantium stopped working completely...indicates no power but it is on.
It may be that your high voltage diode or capacitor has shorted.
The fuse is usually located behind the grille, on the
floor of the oven behind the control panel, between the door switches,
or on the filter board near where the cord comes into the unit.
There
should be a "mini-manual" (tech sheet) hidden inside the unit
behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting, testing, and locating components.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
You can usually find
helpful exploded view diagrams and order parts by entering your full
model number here.
Here are some links you
or someone you know can use (in order given) for test help, but read
the safety warnings first:
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/diode.html
(if it is NOT shorted,
it's probably fine)
http://www.gallawa.com/microtech/mag_test.html
(continuity can be good even
though it is bad!)
http://www.gallawa.com/microtech/xformer.html
To check the high voltage parts, you'll have to remove it from the wall, then remove the outer cover. If
so, the installation instructions are very handy, and it's best to have
two people since the microwave can be heavy and awkward.
You can download GE
owner's manuals and installation instructions here.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
SOURCE: Frigidaire double oven beeping and showing f8 code
Hello there
First i would unplug it for 1 hr to allow the oven internal reset to reset it'self than plug it back in and see what happens but if this doesent help than here is a listing of the code and what it means
F8
Lock motor relay watchdog is ative when it should be off
Microprocessor
checking the operation of the EDC lock relay after self
clean is selected, relay failed. Replace EDC.
Lock switches
Check or Replace
component
SOURCE: beko dvc62 main fan oven stopped working, doesn,t
For all Free appliance repair videos visit our VIDEO
TUTORIALS
You-Tube video "pEhRqdvpiJM" placeholder (do not delete)
1, If the fan motor in the back of the oven is going round and
the temperature light is on (normally little red light), but there is no heat
then you will probably need a new oven element, these are generally very easy
to fit and readily available from our website these can be tested with a
electric meter.
To gain access to the NEFF element you will
have to remove the back plate from inside the oven. Once removed you will see
the fan and element, if you
look closely at the element you will
probably see a small hole burnt in it where it has blown. Sometimes however
there is no evidence of a fault but the element
is open circuit ie:
broken inside the element casing, either way it will need replacing. Some
elements will are fixed from inside the oven and some are held in place by nuts
from the rear of the machine.
2, If your NEFF fan
oven is getting warm but takes a very long time to cook or is burning the food
more on one side than the other, then you need to check if your oven fan motor
is working you will
see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then
you need To replace the oven fan motor
is a little more
expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating
and burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no
heat and no fan then the chances are that someone has put the oven timer
into AUTO mode,
simply put oven back to MANUAL mode and all should be working again.
Hello steve o - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if the error code does not clear contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
