SOURCE: slave drive
If you are referring to creating a slave HDD, then it is not necessary - as this model utilizes SATA hard drives, there is no master / slave concept; it is in the order in which you connect the drives to the connectors on the motherboard. If your reference is to the Optical drives with IDE, then connect the slave drive to the middle connector in the IDE (flat ribbon) cable & ensure the jumpers on both the drives are set to Cable select (CS) - this would be at the rear end of the drive. Connect the IDE cable to the motherboard & the BIOS will automatically assign the drive connected to the end as master & the middle as slave.
SOURCE: flashing amber light on my
Diag LED info is here
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
Appears to be a bad power supply
SOURCE: how optiplex 210l not start
Check the diagnostic LEDs and the power LED for indications of failure
Info can be found here:
System specific info here:
http://support.dell.com/support/edocs/systems/op210l/en/ug/tools02.htm#wp1114558
SOURCE: I have a Dell Optiplex
Click here to visit dell support. The documentation provides details about the light codes and diagnostic procedure.
I think it is a power issue, which is usually indicated by amber light on dell systems. I came accross dell systems with similar indication and the issue was improper voltage either due to faulty power supply or bad connection.
Therefore, i suggest that: -
First, make sure that the connections and voltage to your system is proper.
Also, get the power sully unit checked by a professional for its proper functioning. I may require repair or replacement.
Let me know if any further clarification is required. Hope this helps!
CreativeTECH
SOURCE: my dell pc model optiplex
try it
no sound,DEVICE NOT RECOGNIZED
software
problem -go2 device manager &under device if u see yelow ? mark so
tht driver is missing from my computer REINSTALL IT
Else hardware problem thn Replace speaker/DEVICE
read here
http://pctells.blogspot.com/
http://mailerror.blogspot.com/
