Polaroid TLA-04011C 40 in. LCD TV Logo
A
Anonymous Posted on Apr 15, 2014
Runs for a while and then screen starts flashing
I reboot the system and then it works for a while-then the flashing screen starts again - what year did this model come out
Acer inspire one d260 cannot start system recovery
You should start windows in safe mode. By pressing the F8 key right when Windows starts, usually right after you hear your computer beep when you reboot it, you will be brought to a menu where you can choose to boot into safe mode. If it does not work on the first try, reboot and try again as you have to be quick when you press it. when it starts in safe mode, run system restore and when prompted for a restore date, choose an older restore date, probably one you a sure was perfect 2 days before the blue screen issue. This should get your system running in good shape.
My acer aspire one zg5 got the blue screen. after loading the windows, it will stop then flash the blue screen then restart again and again. what will i do? somebody say my netbook needs to reformat. but i...
Follow these steps to fix a Blue Screen in Safe Mode
Once booting start, select "Safe Mode" from the boot menu.
Scan your hard drive by running your antivirus software . If the program locates an infection, move it to your vault or follow the on-screen instructions. After program completion, if a virus was removed, attempt to reboot your computer and see if this clears up the problem. If not, restart your computer in safe mode.
Restore your computer to a previous point. Click on the "Start" button. Select "All Programs", "Accessories", "System Tools" and finally "System Restore". Choose a restore point on or before the last day your computer worked without error. Finally Reboot your computer to see if it loads correctly.
Acer aspire m1640 not booting all the way up
Reboot2_bing.gif yor machine while holding the F8 key as it boots back up. A menu will apear. Choose -->"start windows in safe mode with networking".
The os will start in safe mode. run an AVG virus2_bing.gif scan, then run Defrag by exploring your computer, right click on C: drive, click PROPERTIES, then the TOOLS tab, click the "check now" button, and only checkmark the top box 'fix file system errors', then click ok, the computer will then tell you it will scan upon next reboot., Now click the DEFRAG NOW button. the choose defrag. After Defrag runs for about an hour and it is finished, restart the system. If is still won't run normally, go back into Safemode buy pressing F8 on reboot, then run a registry2_bing.gif fixing program such as uniblue registrybooster, then reboot again. If it still won't run right, you may want to reinstall Windows and see if that works. If reinstalling windows doesn't fix it, it is definitely a hardware problem.
Good luck.
PLEASE RATE THIS ADVICE WITH SOME THUMBS UP!!!
Acer Aspire 5610 RAM upgrade issue. Sorry, it's long-winded. I included everything. lol I'm trying to upgrade from 1GB (two 512mb modules), to 2GB (two 1GB modules). The max for this machine is supposed to...
first refer to the motherboard's manual and see the max. RAM support.... then go to system properties | advanced tab | start up and recovery | go to settings under system failure....uncheck automatically restart
then when the blue screen appears....note down the error message and error code.... post the message and code to me...
this might ease your problem a little bit....
All of the icons from the screen disappeared!
try to reboot your computer into safe mode.
To use a Safe Boot option, follow these steps:
  1. Restart your computer and start pressing the F8 key on your keyboard. On a computer that is configured for booting to multiple operating systems, you can press the F8 key when the Boot Menu appears.
  2. Select an option when the Windows Advanced Options menu appears, and then press ENTER.
  3. When the Boot menu appears again, and the words "Safe Mode" appear in blue at the bottom, select the installation that you want to start, and then press ENTER.
Then click start
click run
type in msconfig
uncheck everything under the startup tab except your antivirus
and reboot
1helpful
System has been working fine for several years. Now on boot up, shows initial screen with ASUS information (motherboard model P5N32-SLI SE Deluxe, Press DEL to run Setup). No BIOS beeps. Warm reboot,...
Are you able to enter into the BIOS settings by pressing DEL?
If so, load default settings in the BIOS and try booting up again.
Best wishes,
Graemevm
1helpful
Motherboard driver is wiped out
Run checkdisk
Start >> Run >> cmd >> CHKDSK
Then try Save mode again
Screen goes black
It could be a bad backlight bulb.
Top Polaroid Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
