Samsung TV Remote Control Logo
A
Anonymous Posted on Apr 15, 2014
My samsung 3D led multisystem smart TV remote control does not work anymore
If lucky enough, you can switch on TV, otherwise, it does not operate. Sometimes it works and the next hour, it stops operating
A Hoffman
Level 3:
Master:
  • Samsung Master 313 Answers
  • Posted on Jun 03, 2016
A Hoffman
Samsung Master
Level 3:
Master:
Answers
313
Questions
Helped
156835
Points
1043
It needs to be Re-Paired to the TV.
First, fresh batteries, and clean battery contacts if needed.
Then, Try Pairing procedure:
  1. TV off
  2. Bring remote within 3 feet of TV
  3. Push Pairing button (Paper Clip or other pointed object in button hole)
  4. Turn on TV
  5. Should be paired. Try remote channel or other buttons.
  6. If not, try 2 more times.
  7. If still not working, push RESET button first and repeat Pairing.
Samsung remotes for LED / LCD TVs are generally RF, not IR.
Most Universal remotes do not generate RF signals, so disregard advice about codes for Universals.
Please rate if Helpful.
Good Luck !!
  1. TV off
my samsung   3D led multisystem smart TV remote co - samsung-3d-led-multisystem-smart-tv-tiee3lbaghb4kteyvqjgelx1-2-0.jpg
Within 3 feet of TV
PAIRING
and RESET buttons:
5 Related Answers
andy4254
andy williard
  • 226 Answers
  • Posted on Apr 28, 2009
SOURCE: Remote control has stopped working.
your remote needs to be put back in TV mode. press the tv button or slide the switch to tv
Anonymous
  • 6 Answers
SOURCE: want to use samsung remote to control fios box and tv
You can use your own SAMSUNG remote but some of the guide options and dvr buttons may not come across.  If your remote allows you to 'map' the buttons you could circumvent the issue.
Another suggestion would be the universal remote by harmony.  great gadget.  pricey though.
Anonymous
  • Posted on Jun 02, 2008
SOURCE: Program Comcast remote to operate Samsung 46"LCD
The answer depends whether its a Comcast DVR Remote or a regular one. The DVR codes are 4 digit -- the others are 5 digit. I got 0060 to work for my DVR remote.
Anonymous
  • Posted on May 05, 2009
SOURCE: need control code, to operate dvd samsung
Yes. I found the code. To operate Samsung HT-Z 310 with a remote control of Samsung TV, You have to turn off DvD, and then select Dvd on the remote(press the dvd button), press SET on YOU
remote control, input the CODE(020). For different Samsung dvd. you can try.codes from 000-to 080. The DVD button must blep three times. After that swich on Dvd. Enjoy....
Anonymous
  • Posted on Mar 19, 2011
SOURCE: original ak59-00104r remote control device does
Take the batteries off, press the button "0" for 1 minute, put the batteries back on, try it out.
I have a samsung UA55F8000 led. It keeps turning on and off.. Please advice if its just the capacitors or does the whole power board needs to be changes
If you can not see any failed capacitors ( bulging or ruptured case of capacitor ) then you need to replace the entire board.
2answers
1helpful
I want to display the keyboard on my Samsung Smart TV using the remote control that came with it. How do I get it to come up? And, how do I put the browser on the tv in tab mode so I can enter from the...
Download the manual from the samsung website.
However on my Samsung 6800 tv the browser cannot do tabs.
The only keyboard is one where you move the cursor around with up/down/left/right buttons on the remote controls.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
