2004 Chevrolet S-10 Logo
Anonymous Posted on Jun 18, 2009
High pitch whine
When driving down the road every now and then i get a noise like a high pitch whine, i hit 4h then back to 2h and it goes away, sounds like a gear trying to engage while driving
Anonymous
Level 2:
  • Expert 35 Answers
  • Posted on Jun 19, 2009
Anonymous
Expert
Level 2:
Answers
35
Questions
0
Helped
22598
Points
112
Sounds like your one of your hubs on the front axle are staying engaged when you turn off the 4wd. By reselecting the 4wd high and back to 2wd hi it is causing it to release. Get it looked at these can get expensive if damage is done.
1helpful
What is making this 08 caliber 2.0L sxt cvt have a High pitched whining sound at idle and driving?
Possible bearing in one of the drive pulleys. I have changed numerous alternators for this noise. Take the belt off and start the car. If the noise goes away you know it will be pulley related and not transmission related. If noise goes away, spin all pulleys by hand to determine the defective/noisy one
2helpful
2answers
1988 suzuki samurai.when I'm driving down the road the transmission is whining. When I let off gas it stops. I just bought it it's has a new clutch and cable. Don't know if throw out bearing is new.
If it's not whining when you have your foot on the clutch and are stopped, its not the throwout bearing. While driving the throwout bearing isn't being used....
Transmission whine is either in the transmission or differential.
I have a '08 Ford F150 FX4. Recently I had to use my 4 H for a short drive. I had no issues until a couple of days later, when I notice a rattling noise in 2H, which sounded like a rattling noise si
If it isn't a heat shield or something like that,
then your pulling the transfer & taking it apart
Google your transfer mfg case or unit number & see what
problems come up
Call this place
They have a web site
Drivetrain.Com
2answers
High pitched whine
check condition of drive belt and check tension of the belt as it may be slipping under load at revs.
1helpful
I now have a suzuki samuri and do not know how to use 4x4 gears
Using the shorter gear leaver in the samurai, the gear choices are arranged in a simple U fashion. They are arranged in sequence. At left top, bottom, right middle and right top you have 2 high(2H), 4 hight (4H), neutral(N) and 4 low (4L).
2H- Engages rear wheel drive only.
4H- Engages all wheels in 4X4 mode.
N- Disengages all wheels (if you gonna tow your vehicle)
4L- Engages all wheels in 4X4 mode with 50% more torque but you cut your top speed by an equal amount.
If you have the OEM gear knob the diagram of the layout of the transfer box should be imprinted. 2 high should be used on dry and mildly wet paved roads. Using 4L or 4H in these conditions may result in damage to your transfer box. You may use 4L or 4H in any other road conditions.
1helpful
High pitched electronic/dentist drill sound when accelerating.
Probably the front differential, your probably hearing the famous differential gear whine. Change the oil, put Lucas for gears in it. You can get a hand operated oil pump to **** it out through the dip stick if it has one. Then fill it with the recommended amount.
8helpful
6answers
A high pitched whining noise in the engine.
This Noise Description sounds Indicative of the Sounds that come from the Serpentine Belt Or Related parts such as Belt Idler Pulley or Belt Tentioner witch also has a Pulley, but if Tensioner itself is Literally BROKE I've replaced a number like this it will cause a Whining noise . Best case scenario its just the Belt, and if any of the other Problems turn out to be the Culprit the Belt MUST be Replaced Anyhow as Damage is Being caused By the Very Whining you hear.
PLEASE Spend the Extras $ for the BEST BELT as this Drives your Water pump, Alternator, A/C Compressor, Power Steering Pump All Crucial to Control of, easy Steering ,All Electrical-Power Distribution, The COOLING of Engine << VERY CRITICAL Component
The Pulleys usually have a more Hum type Whining. So I would say at Best The BELT , And WORST Belt Tentioner is Broke
2answers
99 nissan pathfinder 4 wheel drive once put into 4 wheel drive popping noise underneath the vehicle
that sounds like a bad universal joint on the transfer case to the front axle. have that checked out
Top Chevrolet Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Chevrolet Expert? Answer questions, earn points and help others
