When my Amana Gas Dryer with stainless steel drum is started up cold it has a loud "Squeek" sound like a loose fan belt on a car. After 5 minutes or so it gets quieter but not all the way to totally quiet. It also sounds at that point it may be a support roller for the main drum. Please provide information at to what is wrong.
SOURCE: I HAVE AN AMANA GAS DRYER THAT MAKES A VERY LOUD
Here is the link for the owner's manual, but it doesn't look like much help. Just cut and paste on the address bar of your browser. http://shop.amana.com/assets/pdfs/literature/40125301.PDF
Once you get through looking over the manual, here is how you fix your dryer:
If you found this solution helpful, please don't forget to rank it.
SOURCE: Neptune gas dryer rattles sporadically when running.
do you fell it rattleing alot? Its can be the rollers are very worn and need to be replaced or the center of the rollers need to be greased up. hope this helps...
SOURCE: Kenmore 417.81042000 Electric dryer has loud squealing sound
My dryer of the same model number had the same issue. The teflon/plastic wear points are worn out or have fallen off. They are about $22.00 plus shipping at the site below. Disconnect the power, lift (with force) the top off at the front of the dryer and you will have access to remove and replace.
Felt glide assembly - Upper felt seal with three glides attached. Comes with adhesive.
Part Number: AP2150497 made by FRIGIDAIRE
www.appliancepartspros.com/modelsearch_model.aspx?part_id=2150497&&model_id=301211
SOURCE: My Maytag gas dryer makes a loud rattle and clanging noise.
Prob. some failure of a bracket or loose inside...
Have a local tecnician check it out.
i think that ll be best cause i can't imagine that will be an easy fix.
I hope this is useful, and greets,
Olivier.
SOURCE: Maytag dryer (LDE5914ACE) loud slipping/thumping sound
yes, it's called a blower wheel... it is what blows the air into the dryer to blow out the humidity through the vent... it has a D fitting and as you use it, the D rounds out and the 'squirrel cage' stops spinning and begins to slip... if you continue to use the dryer without replacing this, you could burn up your dryer motor... it will just over heat....
