Beeping noise that goes on off and on all day and night . Doors are closed and tight. Temperature stays good in freezer and fridge. Please help this is very annoying. Thank you.
SOURCE: kenmore fridge beeping
More likely the light switch is not working or the door/drawer is not closed properly. Regards Advisor
SOURCE: Kenmore Elite side-by-side (1999 model--don't have #)
Evaporator is probably overiced as a result od door not being completly closed at some time recently, turn off and defrost overnight with the doors open, turn on the next day and it should work ok within 24hrs. Regards Advisor
SOURCE: Refrigerator does not cool
If the refrigerator cooling is poor, it may be a problem with the thermostat, the compressor, or the evaporator fan. If ice is accumulating at the back of the fridge, that can also be a reason for poor cooling.
See aso the links below for a more detailed explanation:
It's not cool
Cooling is poor
SOURCE: Fridge does not stay cold
If the compressor is running continually, could be short of gas , or a compressor problem, ie not pumping properly,make sure it has plenty of ventilation
SOURCE: Kenmore bottom freezer 73504. All freezer items fully defrosted.
I went to local.google.com to find fridge repair person nearby. They were able to come out the same day and solve the problem. The starter kit for the compressor was replaced. Sears couldn't make it until the following Monday when I called them on a Wednesday. I highly recommend shopping local and keeping the home town economy moving.
