SOURCE: Wii Wi-fi Internet Connection
When you are not able to connect with Internet from Your Wii, means there is something wrong with the settings. You may go to Wii Fix Guide
and check out the guide available there, This DIY guide will show step
by step pictures to fix the problems yourself without any technical
knowledge.
SOURCE: can not get internet connection....my wireless
http://www.wiichat.com/nintendo-wii-online/5465-wifi-error-51330-a.html
SOURCE: I changed the ssid on my wireless router! I can
Start your wii, go to the bottom of the screen and click on the wii icon.
Than go further in the program to internet conections.
clic on and your wii wil search for a new connection
SOURCE: I can't get my wii to connect to my wireless
go to settings wii settings then click internet and click any connection search for access point then type in pass(optional) and then click ok go back to wii menu and connect
SOURCE: error code 51330 trying 2 connect 2 internet by
Hello!
The usual cause of error code 51330 appears to be that the password
(also known as a WPA or WEP key) entered into the Wii console is not the
same as what your wireless router is set to allow.
This is how to fix it:
Make sure the password is entered into the Wii exactly as it appears in your router's settings. Security keys are case sensitive.
If this does not work, I would suggest doing a power cycle of your modem and router. This is done by following these steps:
