Computers & Internet Logo
A
Anonymous Posted on Apr 13, 2014
Xerox workcentre c2128 When i put paper in bypass tray, sensor dosnot detect this paper
When i put paper in bypass tray, sensor does not detect this paper
Reuel Teoh
Level 2:
Champion:
  • Expert 411 Answers
  • Posted on Aug 05, 2014
Reuel Teoh
Expert
Level 2:
Champion:
Answers
411
Questions
Helped
112606
Points
490
You must manually define the papersize and orientaion of bypass tray at the printer console or printer driver.
Then print bypass tray (e.g. Tray6 on our Xerox).
2 Related Answers
Anonymous
  • 2072 Answers
  • Posted on Jul 09, 2010
SOURCE: Paper size Mismatch on Xerox workcentre 4118
Most likely the tray setting has changed, Here is what to check.
  1. Press the [Machine Status] button on the Control Panel. 'Machine Setup' will be displayed on the Display Screen.
  2. Press the [Enter] button.
  3. Press the [Left] or [Right] arrow button until the required tray is displayed, and then press the [Enter] button.
  4. Press the [Left] or [Right] arrow button until the required paper size is displayed, and then press the [Enter] button.
  5. Press the [Stop] button to return to the Standby mode
I am sure you will find one of the tray settings to be incorrect.
If not, click on the printers on your computer, Right click the 4118 and look in the printer properties. One of those settings may be off.
More likely is that the machine settings have changed for whatever reason.
Aditya Agarwal
  • 49 Answers
  • Posted on Jan 10, 2011
HI wat you can do is Most likely the tray setting has changed, Here is what to check. Press the [ Machine Status] button on the Control Panel..
1helpful
ERROR 024-959
Xerox 6605 paper tray empty error, the paper detect sensor arm and pick up roller get out of place. remove paper detect sensor arm and pull down on pickup roller assembly it should be springy not stiff. once it springs again, put paper detect sensor lever back on, on the right side of that lever gets tucked behind pickup roller assembly. hope this helps. The Magic Man!
2helpful
Error C0...Xerox WorkCentre 5020DN Printer
C-0 declares that the size of the document you are trying to print is incorrect with the paper size you have in your machine's tray. To remove the error, press the red button on the control panel and check the size of the document within the printing properties. If the papre size of the document and the paper in the tray are correct then try to use another tray or bypass tray. If the problem still persists, call for service.
5helpful
What is the fault code 124-373 of xerox workcentre 5230
power down machine,
remove drum,
power on machine,
reseat drum
1helpful
2answers
Xerox 7328 error code 026-717
Make sure the DNS info is properly configured.
http://www.support.xerox.com/support/workcentre-7328-7335-7345-7346/support/enus.html
2helpful
1helpful
I have a WorkCentre 5225 and it is telling me that I have an error (code #071-210) what is this error?
That error specifies a Tray 1 lift failure.
You probably can hear the motor lift 127K38171 when you re-insert the tray, so maybe the lift motor is bad or maybe a sensor
930W00113 is falsely accusing our motor.
Whit
Item, Inc
7helpful
4answers
Paper size mismatch is appearing on the screen
if that is when your printing you have to check and be sure the paper tray size is set correctly. You press the machine status button and make sure, tray 1, 2 and the bypass are set to the proper size paper.
Printer always prints from bypass tray...
Check the setting in / on your computer. Make sure it is not set to default to the bypass tray.
1helpful
3answers
Can't print envelopes
Solution Title: How to print on COM10 envelops from the Bypass tray (PCL6) using a Windows 2000 O/S Resolution/
Solution
thumbsup.gif Fixed! thumbsdn.gif Did not fix. Resolution Role: Fix
Critical Message: The Envelope must be placed in the Bypass Tray face down (flap side up) and Long Edge IN. In Microsoft Word (Word 2000)
    1. Under the Tools tab, select Envelopes and Labels.
    2. Enter your Delivery and Return addresses.
    3. Click on Options
    4. Under Envelope Options; [Envelope size], select Size 10 (41/8 x 91/2 in)
    5. Under Printing Options, select Portrait (LEF) - Long Edge Feed
        • As Feed from, select Tray 5 (Bypass)
    6. Click <OK>
Within the WorkCentre Pro 123/128 print driver
After opening up the print driver [<Start>, <Settings>, <Printers>, double-click on the WCP 128 PCL6 driver], click on Printing Preferences under the General tab.
  • Under the Paper/Output tab
Set the following features as follow:
    • Job Type: Normal Print
    • Paper Size: COM10
    • Output Size: Same as Paper Size
    • Image orientation: Portrait
    • Image Rotation: OFF
    • 2 sided Print: 1 sided Print
    • Stapling: None
    • Output destination: Center Output Tray
    • Offset Stacking: None
  • Under Tray/Layout
  • Set Paper Source to Tray 5 (Bypass)
  • Click on Bypass Tray Settings
    • Paper Type: Heavyweight (1 or 2)
    • Feed orientation: Portrait
  • Click <OK>
  • " on Specify Paper Type and select Heavyweight (1 or 2)
  • " (Apply> and <OK>
  • " <OK> again
In Microsoft Word under Envelopes and Labels, Click <Print> to send the information to the printer.
Note: This setup represents one way of printing envelopes. Other ways setting up some features in a different manner will work as well.
Solution v1.3.20.0 312637.How to Print on COM10 Envelops From the Bypass Tray (PCL6) 2006-04-05 21:57:29
Top Canon Computers & Internet Experts
old marine
old marine
Steve Sweetleaf
Steve Sweetleaf
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
