The firmware for any electronics device tells the hardware how to properly function.
Most devices rarely need a firmware upgrade, however, computer products such as a Seagate hard drive need to have the firmware updated periodically due to computers constantly going through operating system upgrades.
Luckily, you can update your Seagate hard drive firmware with an Internet connection and a few clicks of your mouse.
Connect your Seagate hard drive to your computer if the hard drive is external.
Launch your Internet browser and navigate to the Seagate.com website.
When the site loads click the "Downloads" button.
Click on the hard drive listing you currently own.
This brings up all of the most current downloads for your Seagate hard drive.
The listings of the hard drives have the image, so match your hard drive to the image online if you are not sure what drive you have.
The user manual states what hard drive you currently own also.
If you don't have your owners manual, open "My Computer" (or "Computer") and right-click the hard drive icon and select "Properties."
Here the computer states exactly what model of hard drive you have.
Click the Firmware update and click the "Download" button to launch the download.
Click-and-drag the file into the hard drive if you are using an external hard drive
(open "My Computer," then double-click the removable hard drive icon).
Open the downloaded file and follow the prompts to install the updated firmware.
Hope this helps
Hope this helps
Every Seagate drive requires a few firmware updates during its lifetime.
Seagate firmware must be up-to-date to ensure that the product will run reliably.
Changing the firmware on a Seagate product to a more updated version will improve the product's performance.
Check the Seagate website often for any update available for your drive.
The firmware can be changed with just a few clicks of your mouse on the Seagate Web page.
Click the "Start" button on the bottom-left corner of the screen.
In the window that pops up, click " My computer " or just "Computer."
Another window will show up with an icon for your hard drive.
Right-click the hard drive icon and press the "Properties" option.
This will tell you what model your hard drive is.
For example, your hard drive might be ST31500341AS.
Open your Web browser. Type in www.seagate.com and press "Enter" on the keyboard.
Wait for the webpage to load.
Enter the word "Firmware" and your model number in the search box on the upper right hand corner of the webpage and press "Enter" on the keyboard.
Using the example from Step 1, type in "Firmware ST31500341AS".
Click on the first link that is returned in the search results.
Locate the firmware update. Double-click the update.
Press the "Download Firmware Update Utility" link to start downloading.
Click yes on any pop-up boxes that you may see.
Open the new firmware file by double clicking the file that you downloaded in Complete the installation by accepting all of the default questions that are asked during the installation process.
Hope this helps
Your HARD DRIVE (aka: Hard Disk),
located on the left side of the unit, has crashed. You will need to
replace the HD.
When you replace your hard drive, you
will need to have the latest firmware on a
usb stick. Download the firmware from
the playstation official website onto a usb
stick. Once prompted by your system you
will need to insert the usb stick into the
PS3. Good luck..
You will need 2.5" Sata Hard Drive.
replace the HD.
PS3. Good luck..
replace the HD.
PS3. Good luck..
located on the left side of the unit, is at fault. You will need to
replace the HD.
PS3. Good luck..
